Need help building a PC running 24/7
v0dkaX
Hi Guys!
I would need to get a pc to run a bot/application 24/7.
I'm a quite noob in PC, did alot of reading but still dont really understand server vs computer, currently using a laptop to do the job but have to reboot every 2days due to lag.
Some concern will be:
To maintain the speed (no lag)
Power consumption
Can I build a custom pc for this purpose? Or do I need to get a server pc from dell/lenovo?
Thx in advance! Any help appriciated.
SGTechGamer81
Hi Guys!
Power consumption
the question isn't the hardware, it's just what software are you running 24/7?
If it's mining its better off you build a spacific mining rig.
Otherwise most custom pc need to depend on what job it has to do
yusoffb01
you could get a beelink x45 in lazada for less than 230. comes with 64GB msata and 4GB ram.
8gb ram version available for 280. processor used is gemini lake, 2x faster than atom z8350. Power consumption wise should be 15w.
I dont recommend atom processor if you plan to use multiple instances.
Slowdown
I second that. I have been running Beelink X55 for 24/7 for almost six months now. I do get an occasional reboot like once a week and I am not sure the reason. Other than that it pretty much run 24/7.
v0dkaX
Wow thats seems like the best solution for me! Look up on some youtube reviews it seems great!
I'll try order 1 and try it out.
Tyvm!
v0dkaX
Cool! I'll get one to try!
Tyvm!
