Need help building a seirous gaming rig
tlkchew
Looking to build a new gaming rig.
Main aim is to play Star Citizen.
Will likely get a occulus rift in the future so screen resolution will be based on it.
budget about $2.8k
Suggest please.
tIA
Alternative X
Occus Rift System Requirements:
Recommended specifications: A desktop computer running a dedicated graphics card with DVI-D or HDMI graphics output, with capability of running current generation 3D games at 1080p resolution at 75fps or higher.
https://support.oculus.com/hc/en-us/articles/201835987-Oculus-Rift-Development-Kit-2-FAQ
CPU+ Mobo: GIGABYTE Z87X-D3H + i5 4460 (453)
RAM: G.SKILL RIPJAWS-X 1600MHZ ( 4GBx2pcs ) CL9 (115)
GPU: 2X ZOTAC GTX 970 4GB TWIN FAN (1018)
SSD: CRUCIAL MX100 256GB (162)
HDD: TOSHIBA 1TB 7200RPM (69)
DVD-RW: LG 24X DVD-RW SATA OEM (25)
PSU: SUPERFLOWER LEADEX 750w GOLD (165)
Case: CORSAIR 300R (119)
OS: WINDOWS 7 HOME PREM (120)
Total cost: $2246
Buy at PC Themes, #04-15, and ask for discounts. DIY yourself. If you can't into DIY, go to PC Care & Solution at #02-32 and ask Nigel to help you assemble for a fee.
Disclaimer:
As Star Citizen is not out yet, there is no guarantee that the system will be capable of running the game at 75 FPS on max settings.
kreja
I'm playing Elite:Dangerous with Rift DK2. I would suggest you hold on first. DK2 is 1080p 75Hz which current high rigs barely can make reach 75fps. The consumer Rift is rumoured to be even higher resolution than DK2, possibly 1440p? I don't know if gtx970/980 is up to the job anot...
tlkchew
woah.. ok.. lets hope that the rift is not a vapour ware.
Big dilemma whether to wait or not. at first wanted to wait but my desktop of 6 years AMD64 X2 just died on me few weeks back. all no sound no picutre
kreja
I can only say I wont play Elite without rift anymore...:D
