xXfanaticXx
- Sep 20, 2008
Hello everybody,
I've been having problems with a computer, it can just auto turn on without pressing any thing at all (from cold state). It power cycles, on and off, even if I let it idle in the bios, it can just suddenly turn off and on by itself again and it keeps cycling like that. Sometimes it stays on longer, sometimes less than 20 seconds.
I've reseated the GPU, and RAM, tested the ram sticks, It happens even when using 1 stick.
I tested with a different PSU and still the same problem, it auto turns on/off.
Even with only power cable, hdmi and Keyboard plugged, storage devices all unplugged (sata+power), still running into the same issue.
Any ideas what might be causing the issue? It just happened out of the blue.
Thanks in advance!
Thanks in advance!
