Need help: conputer unable to turn on
jayz89
Hi all, my computer suddenly shuts off then cannot turn back on
When i press the power button, it will like power on then off straight away, then into a loop always on then off like that
was watching champions league then suddenly leh sian how ah?
Sry if i post wrong section
Any help is appreciated
gld998
hardware failure. Try takeout n put back RAM, then can try to bootup.. another is try to takeout n put back display card n try to bootup
oddbasket
Try reset your bios settings by removing battery.
Also check expansion slots for dust, especially gfx card. Gfx card fans tend to push and accumulate dust onto the pcie slot connectors.
jayz89
I took out ram and gpu and clean, put it back but still same leh. Any other solution to try?
Is ivan aka fortan still using same number u guys know. ?
Providence
Do you have a spare PSU or graphics card lying around? You can try to swap each of both items first and see the result.
If both items still cannot resolve the issue, then the motherboard may be the culprit.
I think my father's PC had the similar issue and now he is playing XBox 360 instead. Hahaha... He totally gave up on the PC.
jayz89
I called up my seller for the pc, tried some ways but couldn't save it, just went down to the service centre to repair my motherboard, up lorry liao neeed take 2-3 weeks to repair
Wtf...
