Need help DIY rig for video editing
Delsamor
Hi all, can help me build a desktop mainly for video/photo editing purpose and surfing net? No need for games.
Main Usage: Video/photo editing, surfing net, youtube. No games.
Budget: $1,000
Current Rig (6yrs)
1. Intel i5 2500 3.3ghz quad core processor
2. MSI P67A motherboard
3. 16gb kingston ram
4. MSI R5850 1GB Twin Frozr II Graphics Card
5. Fujitsu SSD
6. Seasonic 650W PSU
7. Microsoft windows 7
I can reuse my SSD as additional, monitor/KB/mouse ect...
Thanks!
singupingu
CASE: Tecware F3 $49
MOBO+CPU: Asus H110M-A M.2 + i5-7500 $403
RAM: Kingston Valueram DDR4 2133MHz 16GB $170
PSU: EVGA B450 $79
SSD: OCZ TL100 120GB $85
HDD: Toshiba 1TB $63
GPU: Zotac GTX 1050 TI 4GB $212 from Qoo10 after $20 off - sold by Cybermind
OS: Windows 10 Home ($11 via carousell)
TOTAL: $1072
Prices quoted from PC theme or otherwise stated.
If possible, up your budget a bit more and get AMD Ryzen 5 1600 + Asus Prime B350M-A 6 cores 12 thread bundle. Otherwise, downgrade to GTX 1050 2GB.
Sent from Overpowered Phone Mark III using GAGT
Psycovirus
PSU: EVGA B450 $79
TOTAL: $1072
Quote from singupingu with some changes and most are quoted from Bizgram price list, Sim Lim Square.
Removed the GPU as Intel has Integrated GPU built in.
CASE: Tecware Alpha F3 M-ATX Case - $45
MOBO+CPU: Asrock B250M Pro4 + i7-7700 - $571
PSU: Thermaltake Smart 530W Semi Modular - $78
SSD: WD Blue SSD 2.5” SSD 120GB - $79
HDD: Toshiba 1TB $61
GPU: Integrated
Total Damage: $1015
Since you do not game, GPU is not required. Integrated is able to push enough pixel for video/photo editing.
Took i7-7700 over the i5 because of Hyperthreading and better turbo speeds for heavy work loads. Also, choose a better chipset, B250M for better stability . Heavy workloads such as exporting videos/photos will stress the VRM on the motherboard, which is not robust on H110 boards. B250 is made for business use thus are much thoughter.
singupingu
GPU: Integrated
Total Damage: $1015
A good alternative also. I chosen gpu for much faster rendering of the finished product, as long as the software ts uses can utilize gpu processing power.
Irenicus
My suggestions for this build uses AMD Ryzen R5 as it has more cores and threads than Intel i5 or i7 which makes it more suitable for video and photo editing.
All prices quoted from Tradepac (unless otherwise stated):
CPU & MB Bundle: AMD R5 1600 + Asus Prime B350M-A @ $439
RAM: Kingston Valueram DDR4 2133MHz 16GB (8GB x 2 sticks) @ $168
GPU: Palit Geforce GTX1050 StormX 2GB @ $145 (after buying Lazada $100 Gift Card at 20% off from Wogi, alternatively use $15 off Citibank card code or $13 off code if you don't have a Citibank card)
SSD: WD Blue SSD 2.5” SSD 120GB @ $79 (Bizgram)
Hard Disk: WD Blue 1TB Hard Disk @ $68
Casing + PSU Bundle: Tecware F3 + FSP Hexa 450W @ $80
OS: Windows 10 Home @ $11 (Carousell)
Total cost (with OS): $990
You can reuse your SSD if it's the same capacity as what I suggested or to lower the cost of the entire build.
Delsamor
Thank you all for the suggestion!
I want to get a GPU instead of integrated ones as my software uses GPU to render effects and transitions. I will research more based on the suggested builds :)
Delsamor
Sorry I have more question.
I forgot that my computer need to be internet enabled. So I need to get a network adapter card right? I am currently connecting using direct Ethernet cable.
undead102
You can use direct ethernet cable for internet then don't need the usb network adapter. If you want use wireless then got to get the wireless usb or pci e network adapter
Delsamor
My current PCIe network adapter have the setting "1.0 Gbps Full Duplex" for Singtel fiber. If I don't get a network adapter, does the mobo have the same setting also?
ragnarok95
Senior Moderator
Senior Moderator
Buy a 2nd hand 2600K. Less than S$200 now.
Settle.
Graphic card can change to a GTX1060.
Settle.
enenyi
Settle.
Settle.
Problem is not the chip but the board.
How many Ivy Bridge or Sandy Bridge boards are still working now? Of those working ones, how many owners of those boards are willing to sell them off? :s13:
Given AMD's Ryzen giving Intel a run for its money at the lower end of the spectrum, getting an R5-1600 is the best value-for-money option out there without having to hunt high-and-low for a compatible board.
ragnarok95
Senior Moderator
Senior Moderator
His board tank for so long liao. It's a beast. Save up more money then one shot do a good one. :D :D
2500 to 7500 you feel zero diff in real life usage... i know.. i am using them. :s13:
Delsamor
Definitely tanked through many wind wind rain rain situation and still going strong :s13:. But I figured it is time to get a new rig :D
enenyi
2500 to 7500 zero diff in real life usage...to edit videos? Woah, which magical software u use to edit videos, share with us leh...:s13:
For me, moving from a 4-core 4-thread i5-3570k back then to a 6-core 12-thread i7-5820k chip already cut my exporting times by half in Adobe Premiere Pro, havent factor in GPU acceleration and RAM usage yet. So i feel that R5-1600 is the best for TS unless TS willing to pay for for R7-1700.
Disclaimer: if TS video editing is not even heavy (e.g Windows Movie Maker style or very light Adobe Premiere Pro), then dont even need to upgrade and spend $1k. Current rig can do the job well enough.
Delsamor
Thanks for the insights. I am using Da Vinci Resolve and alternating other NLE software as well as occasional photo editing. I guess the 2 game changers here are CPU and GPU. If I have more budget, I would definitely get R7-1700 and GTX 1060.
enenyi
Then prioitize CPU over GPU. Coz almost everything goes thru the CPU for rendering/exporting. The GPU does nothing more than help offload some rendering from the CPU, and that is if u actually use very specific effects like blurring, vignetting etc (google for the list of effects for the software u using). If i were u, i would get an R7-1700 with a cheapo but decent motherboard, then see if i got enough to get a GTX 1050 or RX550 or not. And certain software prefer certain GPU brands. I know that Adobe is okay with either Nvidia for CUDA acceleration or AMD for OpenCL acceleration, but other software would better with one of them. And also check for RAM usage for the software, coz some software like Adobe are RAM-hungry and will gobble up any RAM u have left, bottlenecking the export times instead.
Irenicus
You can reuse your SSD, casing or power supply to free up your budget for a better CPU e.g R7-1700 or GPU e.g GTX 1060
MoneyFace =p
Here is my take:
CPU: AMD Ryzen 5 1600 @ $279*
MB: ASUS PRIME B350M-A @ $125"
RAM: Corsair Vengeance LPX DDR4-2400 CL15 16GB @ $169^
GPU: Zotac GTX 1050 2GB Mini @ $148"
SSD: Crucial MX300 275GB @ $129"
HDD: Western Digital Blue 1TB @ $68 (SLS Tradepac)
PSU: FSP Hexa+ 450W @ $49°
CASE: Tecware F3 @ $35`
OS: Microsoft Windows 10 Pro 64-bit Product Key @ $2 (Taobao)
Total: $1004
Prices from Lazada listings unless otherwise stated.
Price after 20% off Fuzzie App $300*/$200^/$150"/$50° Lazada gift card purchases
`Price after WOWAPP5 $5 off min $20 Lazada coupon
Delsamor
Actually, the prices you all posted here with what lazada what gift card, does it mean I have to buy them individually and assemble myself? If I know nuts about computer assembly, can I get someone to help me?
MoneyFace =p
Lazada GC from Fuzzie App. You can always bring down the parts to any PC hardware shops to assemble for a fee...
