Teo Ming Ern
- Jan 1, 2000
Hello,
I need some help here... I have two 500 GB Innostar 2.5" HDD that were extracted from two brand new Acer laptops. They were put into two HDD enclosures that are USB 3.0 compliant. And they were left there for a number of years untouched.
Yesterday, I decided to format them to use as storage HDD... but when I plug in to my Windows 10 laptop, Disk Management shows that they have been partitioned into 2 partitions with the boot sector still intact. There was not way for me to combine the partitions in Disk Management into 1 partition.
I went online and found a tool called MiniTools Partition Wizard. Reading the FAQ, I wiped the hard disk. I chose to write over with 0. For the first HDD, after wiping, I could see Tim HDD as G drive in Windows Explorer. I could click on it and see that the drive was empty under Windows Explorer. I didn't test transferring a file over. Anyway I plugged it out and repeated the same process with the second HDD... since this process took so long, I left the desktop running and went to sleep.
This morning, when I plug in both the HDD, they can't be detected by Windows Explorer or even Disk Management. Under Device Manager, I can see the two HDDs, Windows says no problem with either HDD...
I have no idea what happened or if I did the right thing... I suspect that the two HDDs are not formatted to the right file format and hence Windows can't detect them... but since the HDD cannot be detected within the Windows environment, I really can't initialize the disks or format them or do anything...
Even the partition software I use, MiniTools Partition Wizard can't detect them. I tried CrystalDisk also can't see the disks.
Unfortunately I don't have another laptop or desktop at home to check them...
Anyone can help? Much appreciated...
