need help for 1k gaming rig
ABNNASGM
looking to get a rig for around 1k. need some recommendation from hardware expert. major thanks.
no need os
nippp0n
CPU & Mobo: i5-3450 & Asrock B75M-DGS @ $300
Ram: Kingston 1600mhz value ram 8GB @ ~$72
ODD: Samsung DVD RW @ $22
HDD: Hitachi Deskstar 1TB @ ~$80
GPU: Powercolor 7870 Myst @ $311
Case: Asgard Midgard II @ $87
PSU: FSP Raider 550W @ $78
Total: $950
Buy and build at Tradepac.
Some things to take note when dealing with Tradepac:
  • Be firm with your decision when buying from Tradepac. Don't be swayed by their sales assistant to upgrade and buy more expensive components which you don't require.
  • Check all the components you plan to purchase are correct before you make payment.
  • Stay at the shop and supervise them as they assemble your rig and make sure they return all spare chassis parts. You might want to take note that Tradepac cable management skills may not be up to your satisfactory level.
