Need help for a home office desktop
myename
Hi guys
I want to build a basic home office desktop. It will be my first build and wanna seek some advice or recommendations. I know it might be cheaper buying a manufactured set but I also want to try it out first as i intend to build a gaming one soon and dont want to screw that up as it would be more expensive.
It will be used for ms office, video streaming, surfing net, and basic gaming (mainly flash games).
I am thinking between an i3 or dual core. (Would a dual core be sufficient?)
Would appreciate a recommendation for combination of mini ITX motherboard + processor. Preferably with wifi, or will a separate wifi be better?
Case: I like the design of Inwin BP655 with 300W PSU (where can i buy it in SG?)
RAM: 2 x 4gb RAM
Storage: 240GB SSD
Any particular brands to look for for each?
My budget is around 500, including a windows OS. Is it possible or should I change to HDD instead?
Thanks all for your help in advance.
ZrE0_Cha0s
myename
sorry sadly nope. but is it alright for you to get a ext one?
mini pc is something like this:
http://uds.ak.o.brightcove.com/7345....mp4?pubId=734546229001&videoId=4084999313001
and there is usb slots for u to use ext dvdrw.
maybe u can check with him where can u get 1. : http://forums.hardwarezone.com.sg/hardware-clinic-knowledge-base-33/nuts-about-nuc-klub-5347419.html
Thanks for the advice, but i prefer one together w the pc to avoid all the wires outside.
Does that mean that wifi-included mini itx pc would not be possible with that budget? What would be the minimum cost? I have some room to increase the budget but would ultimately like it to be cheaper than buying a manufactured one.
ZrE0_Cha0s
well its not necessary to get wifi onboard just that i find that a small form factor will be good for your usage.
And if this is so, maybe u can still can get wifi adapter (those PCI-e card)
ASROCK H81M-HDS + G3258 @172
Kingston 1600Mhz 8GB @47
Zotac T500 240GB @ $73+3^
ASUS PCE-AC56 Dual-Band CARD @99
Microsoft Windows 8 Professional 64-bit Product Key [OEM] @ $30 (Reddit)
Upgrade for free to Windows 10 via free Windows 8.1 update. (u have to do it before 29 July 16)
Total: 424
All parts are taken for PCTheme except for SSD from lazada.
As for ur casing and PSU i really have no idea where to get :(
As for ur lan card i select the AC card(dunno is it slow or not)
All Lazada prices inclusive of delivery charge
*Price after Lazada App Maybank Wednesday / CITIBank Wild Weekend 10% off max $30 discount
myename
Total: 424
Thanks a lot for your input! Will consider both options :)
I found the case on aim resources fb but will have to check if they have stock..
ZrE0_Cha0s
oh and I have forgotten about dvdrw, u can get any OEM from PCT @25.
myename
Okay got it thanks!
And sorry i'm a bit noob at this.. for LAN card is it necessary if i can get pcie which you mentioned? Because of my home network configuration there is no network port in the room which i will be using the pc.
ZrE0_Cha0s
oh what i reco u is a pci-e card, not usb adapter. beside that its the latest wifi AC card, so basically if u have any new routers that is AC can use this card to get stable connection( speed wise will depends on ur environment as well as ur hdb design and beside that your distance from the router to pc).
myename
Ah ok! Sorry just did a search on it. Thanks!
MoneyFace =p
Hi guys
RAM: 2 x 4gb RAM
Storage: 240GB SSD
If you love In Win BP655, you'd love this even more :D :
CPU+MB: Intel Pentium G4400 + MSI H110i PRO AC @ $219 (Cybermind)
Best value mITX motherboard with Intel AC8260 WiFi adapter!!
RAM+SSD: Kingston ValueRAM DDR4-2133 CL15 8GB + Zotac T500 240GB SSD @ $110+3+3*
CASE+PSU: In Win CHOPIN BQ696 Aluminium [Silver/Black] + Powerman IP-AD150A7-2 H 150W Flex ATX PSU [80 Plus Bronze] @ $145 (AIM Resources)
Very sleek, super thick 4mm and high quality made aluminium chassis.
Just 4.5 litres!!
Comes with integrated energy-efficient PSU (made by FSP) as well.
More info: http://www.inwin-style.com/en/goods.php?act=view&id=Chopin#product_tab
OS: Microsoft Windows 8 Professional 64-bit Product Key [OEM] @ $30 (Reddit)
Total: $510
Recommended:
CPU: Intel Core i3-6100 @ +$79
Flash games appreciate higher clock speed.
Buy others from Lazada Singapore. Haggle for discounts!
*Price after Lazada App HTNSNEW 15% off spending max $20 discount (for new customers)
Use this before any other code to prevent nullification
In Win CHOPIN BQ696
myename
Just 4.5 litres!!
Total: $510
Recommended:
In Win CHOPIN BQ696
You are right, i like the design on this case too. :)
But i forgot to mention in my 1st post that i'd need a 5.25 external drive bay as well for a dvdrw drive. Would you have any cases to recommend? I pretty much like most of inwin's mini itx cases aesthetically!
MoneyFace =p
Why not get an external one? Do you really use it often? Most people (including myself) already left it to die since years ago...
myename
Well it was one of the first and only requirements from my mom as it's actually for her to use so i want to stick to that as far as possible. I'll give it some thought
MoneyFace =p
An USB-based slim external DVD writer drive will cost about $30
If she die die wants ODD integrated inside PC, it will inflate the chassis size to double at 8-9 litres FYI.
ragnarok95
Senior Moderator
Senior Moderator
Get a slim drive. Connect via USB. Stick it to the small casing.
Problem solved.
