need help for budget gaming rig
TigBits
Budget is $800 or hopefully cheaper. No need kb, mouse, gpu and monitor.
Need os.
Main Usage: mainly for watching shows, torrenting and playing dota2 max in 1680x1050. Also using Firefox and dota2 together to not lag the com
Planning to upgrade in future 8-9 months time to much better specs. Current com (quad core gs9600 gpu) broke down so need to get a slightly better one to tong for awhile till I upgrade.
Thanks in advance guys
royfrosty
Need os.
$800
Asrock b75m dgs + i5-3350p ~ $271
Kingston value ram 8gb ~ $93
Hitachi 500gb deskstar ~ $60
Powercolor 7750 1gb ~ $122
Cm 311 + fsp hexa 500w ~ $105
Windows 7 home premium 64bit OEM ~ $115
Samsung odd ~ $21
Total $787 buy at tradepac. Diy
TigBits
$800
Samsung odd ~ $21
Thanks! I do not need the gpu, have a gtx650 palit as a gift. Should I use the $122 to get a better processor?
royfrosty
If that is the case then
MSI b85m g43 + i5-4570 ~ $356
WD blue 1tb ~ $80
Samsung odd ~ $21
Total $770 buy at tradepac. Diy
