Need help for budget gaming rig
royfrosty
$1800 everything in
MSI B85M G43 + i5-4570 ~ $347
Crucial 8gb 1600mhz ~ $89
WD Blue 1tb ~ $76
Plextor m5s 128gb ~ $128
Gigabyte r9 28XOC 3gb 3x Windforce ~ $439
Seasonic g650 650w 80+ Gold Modular PSU ~ $135
Sharkoon BD28 Blue ~ $77
Samsung ODD ~ $21
Windows 7 Home Premium 64bit OEM ~ $115
Dell s2340L 23inch IPS Panel ~ $219
TP-Link WDN3200 N600 Wireless Dual Band USB Adapter ~ $45
Steelseries Kana V2 Gaming Mouse RED ~ $49 (Cybermind)
Total ~ $1740. Buy at tradepac unless stated. DIY
The remainding budget of $60 up to you to decide what kind of keyboards you like. For me it is advisable to spend a little more for a mechanical keyboard. Last longer and very good for gaming needs.
Looking at a min of $130 for a mechanical keyboard. Last a lifetime. So it depends on what you really what you want.
LiloStitch90
Thanks. This setup able to play in what settings? Can it last 2-3 years?
I decide to drop OS, can you help me rebuilt the rig?
Sorry for stupid qns does it have usb port on the machine?
royfrosty
It can handle ultra settings for most 1080p gaming
$1800 everything in
WD Blue 1tb ~ $76
Crucial m500 240gb ~ SGD$169 (Amazon)
Samsung ODD ~ $21
CM QuickFire TK cherry Brown/Red or Blue switches with White/Red or Blue Backlit LEDs Mechanical keyboard ~ $139
Total ~ $1805. Buy at tradepac. Unless stated.
Go mechanical keyboard. Good investment and last a lifetime.
MoneyFace =p
Because of some financial problems i have to scale down to <$1200 for budget gaming rig.
No need OS and mouse. Need wifi card, monitor and keyboard.
Hopefully can build this month when i get my pay.
With this budget can i get a decent rig?
Please help me. Thanks
CPU+MB: Intel Core i5-3350P + ASRock B75M-DGS @ $271
RAM: Kingston ValueRAM DDR3-1600 CL11 8GB @ $97
GPU+PSU: PowerColor R9-270 2GB OC + FSP Hexa 500W [80 Plus] @ $298
SSD: Kingston SSDNow V300 120GB @ $115
HDD: Western Digital Blue 1TB @ $76
ODD: Samsung 22X CD/DVD Writer [OEM] @ $20
CASE: Sharkoon REX3 Value @ $69
DSP: Dell S2340L 23" LED [e-IPS] @ $219
PHP: Logitech MK120 @ $17
WIFI: TP-Link TL-WN722N Wireless-N 150 Mbps [USB] @ $22
Total: $1204
Buy and Build from Tradepac, #05-18.
Store Bundle
MoneyFace =p
Or if you wish to do away the SSD for better gaming experience, you may consider this:
GPU: Zotac GTX 760 2GB @ $320
PSU: FSP Hexa 500W [80 Plus] @ $58
DSP: Dell S2240L 21.5" LED [e-IPS] @ $199
PHP: Cooler Master Devastator @ $69
WIFI: TP-Link TL-WN722N Wireless-N [USB] @ $22
Total: $1201
LiloStitch90
Why drop OS? downloaded liao ah?
I have spoilt laptop, possible to use my laptop OS Key? Windows 7 Home Premium 64bit.
Total: $1204
Store Bundle
Thanks for recommending. May i know what settings can i play with this rig.
Some games that i play, NFS Rivials, COD Ghost & BF4.
shadow84
Sadly you cant as it is tied to your laptop mobo. Unless you call up Microsoft and convince them that your laptop is damaged and would like to transfer OS to desktop. Low chances of survival but worth a try.
LiloStitch90
Okay.. then have to spend abit more for OS :(
Hailgod
instead of telling them u want to transfer to desktop, tell them u want to get a new motherboard for your laptop. They should buy that.
MoneyFace =p
Nope the master key used to activate the pre-installed Windows is different from the one on the COA sticker affixed to the laptop backside. While the master product key used on these pre-installed laptop is universal across the entire brand, the one on COA sticker is unique and can be used on other PCs. If you happen to climb that SLICk mountain, you will know what i mean... ;) :D
But if i were TS, i would trek the hill to the bountiful pasture... :s12:
LiloStitch90
Total: $1204
Store Bundle
Total: $1201
Which one should i get? Can i notice any performance improve for 2nd rig compare to 1st one? :s11:
shadow84
Nvr try before... always tot OS is tied to mobo, be it laptop or desktop or OEM.
Next time my laptop spoil, i go try...
MoneyFace =p
You are trade in the SSD for GTX 760 (about 25% faster over R9-270) and better peripheral (Cooler Master Devastator):
Hailgod
in between 650 ti boost and 660.
However, you can overclock the 750ti quite alot and just about match gtx 660's performance.
