Need help for DIY Desktop
nitedr3amer
Hello~~
MOBO + CPU: Gigabyte H97M-D3H / i5 4690
OS: Window 7 64 Bit
HDD: 3.5" Seagate 7200 rpm 1TB
GPU: Gigabyte GTX 970 4gb (ITX) Winforce
RAM: Kingston HyperX FURY 4GB 1600MHz DDR3 CL10 DIMM x2
CPU Cooler: CM Hyper 212X PWM Cooler
PSU: Cooler Master Thunder 600W
Casing: Corsair Carbide 200R ATX w/window or CM HAF 912(Advanced) w/USB3
1) are those parts(other then OS) competible?
2) which casing is more recommended?
royfrosty
A bit weird config.
Swap the ITX version of GTX970 to a normal 970.
Go for 8gb instead of 4gb only. Either a 4gbx2 or a single 8gb.
Swap out the PSU to a better brand and more reliable PSU.
Such as Seasonic, FSP, Superflower.
Jian19
Budget ?
i5-4460 + Msi h97m g43 ~ $404
G.skill 8gb ddr3 ~ $100
Plextor m6s 128gb ssd ~ $99
Wd blue 1tb ~ $75
Msi gtx970 armor edition ~ $499
Fsp aurum s 500w ~ $89
Fractal design arc midi r2 ~ $139 / Fractal design R5 ~ $149
Win7 64 oem ~ $130
$1535 buy and assemble @ pctheme ask for discount.
Hello~~
OS: Window 7 64 Bit
Check this out to choose a suitable PSU. http://www.tomshardware.com/forum/id-1804779/power-supply-unit-tier-list.html
As its like the heart of your whole system you would want to get a reliable one as you don't want it to bring other components down as well when it fails.
nitedr3amer
A bit weird config.
whats the difference between itx and normal 970? there is also gaming 970. i really dk the difference as i checked on gpuboss.
for ram wise i typo=x its x2 =x
icic i will see what can i change to for my psu=D
thanks alot!
trento
Itx means for itx smaller board. But since yr using atx case, no need go small. Btw, i have a 200r case to let go cheap. Pm me if keen. Still mint
nitedr3amer
icic. thanks for the info man=D
im currently looking at it:D
nitedr3amer
woooo. cool! thanks for the info=DD
well do. when i have settled with the current configs i have, i will see if i wan to get it from u or not=D thanks for the offer.
Jurchen King
When was Superflower known as a reliable PSU brand:s13:? I know FSP is to a certain extent, but only their Aurum series.
When it comes to PSU, I only swear by Seasonic or Antec :s12:
nitedr3amer
OS: Window 7 64 Bit
HDD: 3.5" Seagate 7200 rpm 1TB OR
3.5" WD Caviar Blue 1TB
SSD: Samsung 850EVO 250GB SSD SATA3
GPU: Gigabyte GTX 970 4gb Windforce
PSU: Cooler Master V750S 750W 80+ Gold Modular or
Seasonic X Series 650W Modular Gold PSU
after considerations and feedbacks from u guys, i had edited accordingly.
what about this config? still weird...? =x
royfrosty
Then you need some updates on psu. Go ahead and read all the reviews in johnnyguru.
alifffresto
im not sure if singapore has superflower or not. =x
yes there is... but only on selected retailers in sim lim, unlike seasonic and corsair etc.
Correct me if i'm wrong but so far only saw it at tradepac and pcthemes de...
royfrosty
That was the beginning. Now most stores should carry in. Tech Dynamic is the distro.
