Need help for gaming rig
foo9883
Please state games you want to play on mid-high settings.
Mid-high on minecraft can use integrated gpu
Mid-high on crysis 3 $1200 isn't going to be enough
LiloStitch90
Mostly new game which release this time.
if i scale down to 720p instead will budget be enough for mid-high end?
I need to use for school project so prefer to get a pc as long can have the same graphic like ps3, xbox or better is fine with me.
sharkapl
if you dont want SSD 1200 sure ok
3470 + Asrock B75 + pro 3 = 325
1 x kingston 8gb DDR3 Ram = 77
1 x hitachi 1tb hdd = 80
Samsung DVD Rom = 21
sharkoon t28 = 86
powercolor 7950 = 385
FSP plat 550w = 125
Win 7 hp 64 bit OEM = 115
total 1217
Tradepac
CASH IS KING, will get you some discount
if cost is too high u can always drop to fsp raider 550w which is 78 but non modular
if you dun need OS u can easily put a SSD in
LiloStitch90
i need monitor kb & mouse too:o
does amd card better then gefore? if i change to 650 or 660 instead will get better performance?
sharkapl
3470 + Asrock B75 DGS = 306
1 x hitachi 500gb hdd = 60
bitfenix merc alpha = 59
powercolor 7850 pcs+ = 249
FSP raider 550w = 78
total 965
Tradepac
if u want kb and mouse and mouse like Razer then its really out of the qsn
with the remaining money left you can get a 20" or 21.5" monitor
but keyboard and mouse i suggest you fork out abit more for those
Taengoo
Sorry to hijack, if wan build a new rig from scratch, can play dota 2 at max settings with no lag, u all think can below $900 with windows OS?
sharkapl
dota 2 not very high requirements actually, lag means internet lag
if you really want to buy a new rig can suggest
powercolor 7770 pcs+ = 166
total 882
this setup u can still play other current games in the mid settings, in future just buy a new gpu if u want to play other graphics intensive games will do
Spiderman!
which shop in sls is reliable to go for bundle?
i interested in getting those pc package. 1shot settle that kind
shawntyq
actually hwc recommendations are better
cos those shops bundle may not be the optimal choices for ur needs.
and for the given price there are better substitutes available.
anyway the shops i recommend would be fuwell,bell,pctheme.
sharkapl
shop bundle not say not good
but they are just trying to clear those unpopular stocks :s13:
nippp0n
If you want to play safe, go for established shops like Fuwell, Bizgram or PC Themes but be prepared to pay more.
Personally, I don't really like PC bundle package offer by the shops. Either the parts they use are a bit mismatch or the parts they use are not very good.
Taengoo
total 882
Wow tyty!!! Will google and read up on the parts tmr.
LiloStitch90
Is it possible to build a rig without graphic card next time then get it?
If can any recommend for 1200 without graphic card but need monitor and keyboard. No need mouse and os
nippp0n
$1200, can get an entry level gpu, monitor and keyboard.
CPU & Mobo: i5-3470 & Asrock B75M-DGS @ $306
Ram: Kingston 1600mhz value ram 8GB @ $74
ODD: Samsung DVD RW @ $21
HDD: WD Blue 1TB @ $81
GPU: Gigabyte GTX 650 Ti Boost @ $250
Case: CM K350 @ ~$69
PSU: Seasonic S12 520W @ ~$89
Monitor: Dell U2312HM @ $250
Keyboard: Logitech K120 @ ~$12
Total: $1152
