Need help for graphic card upgrade
asnnlim
Hi there,
i bought a desktop from aftershock for my daughter on 2018, recently she told me she wants to upgrade her graphic card as some games she play will lag, can recommend me a cheaper graphic card to upgrade, i don't mind buying a 2nd hand ones as i hope will last her a few years before i change a new desktop for her. is changing the graphic easy task as my computer knowledge is limited. below are her existing specs
Chassis : Hypergate : H200I White
CPU options : Intel® Core™ i7-8700 Coffee Lake 6 Core Processor (12M Cache, up to 4.6 GHz)
Motherboard (Hypergate) : ASROCK Z370M ITX/AC
Graphics Card - HYPERGATE : NVIDIA Geforce GTX 1060 6GB GDDR5
27" full HD monitor
Random Access Memory (RAM) (Desktop) :16GB (8GB x 2) DDR4 2666MHZ
CPU Cooling System (Desktop) : WATERCOOLING : AFTERSHOCK Glacier 120 closed loop watercooling
Solid State Drive Primary Bay (Desktop) : 250GB SAMSUNG 970 Evo NVMe M.2 SSD (Read up to 3,400 MB/sec, Write up to 1,500 MB/sec)
First Hard Drive (Desktop) : TOSHIBA 1TB 3.5 INCH HDD (Buffer Size 32MB)
Wifi - NEXT AND IMPULSE : 802.11ac WiFi (2.4G / 5G WiFi) With Bluetooth 4.0
Operating System(OS) : Windows 10 Home 64 Bit
tigerwoods
Hi there,
What games she play?
Rogue
Monitor used is 1440p or 4k? If want to run 4k, need to buy the top end cards... 1440p, either 2080TI or 3070...
Phen8210
It's better to contact aftershock and ask them for the PSU model before making changes. They tend to use low-end PSU even for high-end systems.
I would upgrade to 3060, given the PSU is decent.
86technie
Hi there,
27" full HD monitor
This spec most games should be playable, depending on game try to lower the setting.
As well as if you know how to check the CPU temperature as liquid cooling for PC that old
can be faulty.
https://www.hwinfo.com/
Suggest bring to a shop let them check.
NvidiAmd
Hi there,
27" full HD monitor
Need to double check with her what does "lag" means. Most likely it means low fps but it could also mean high latency.
If assuming the lag is low fps, then change the game settings to medium, should be able to maintain 60+ fps gameplay.
As mentioned by 86technie, the current computer spec i think is good enough for gaming on FHD resolution. So I would not recommend to upgrade GPU for now at least.
obichacha
If play genshin impact can feel laggy , really need to upgrade gpu, from gtx 1660 insufficient anymore.
Can go for Rtx 3060 or 3060 Ti save for future monitor upgrade to 1440p.
bpwong30
https://pc-builds.com/games/bottleneck-calculator/result/0NZ0Ve/1920x1080/2R/ark-survival-evolved/
Surprisingly for this particular game, the culprit is the processor, not the GPU, see the following calculator result:-
Intel Core i7-8700 is too weak for NVIDIA GeForce GTX 1060 on 1920 × 1080 pixels screen resolution for ARK: Survival Evolved.
While playing ARK: Survival Evolved game, processor Intel Core i7-8700 will be utilized 100.0% and graphic card NVIDIA GeForce GTX 1060 will be utilized 89.6% .
Phen8210
100% and 89.6%, time for new rig.
Phen8210
I wonder how accurate is this calculator as if the results was independent seperated the CPU and GPU results calculated instead of combined assessment.
I think not too far off. I used to have GTX 1060 with Ryzen 1600x and it couldn't drive the GPU to 100% that often.
Only when using Ryzen 3000 then I saw the GPU working to the maximum.
Yongkit
I am surprised even my cpu is not strong enough to play this game at 1080p
KleoZy
hmm.. the question is.. what is enough.. technology never enough.. lol.. anyway calculator is just a guage, it's AI not actual game play. so trust your instinct.. "let go luke.. trust the force" (Quote from StarWars Episode IV)
