Need help for Motherboard
zacky1223
Hello bros and sis, I need recommendation on a new build.
First of all I am not too sure if my current CPU will be a good upgrade to the current Kaby Lake.
I would need Motherboard and CPU. (Motherboard RGB)
RAM (Can have or dont have also can lol) *Not planning to overclock too.
New Casing (Prefer to have full transparent panel on the side. Wanna go RGB :p)
Budget less than $800
The rest of the parts will be reusing.
Thanks for the help in advance. :)
xtractor
:s13::s13::s22::s22::D:s12:
i oso thinking for the upgrade but i will wait until next CPU GEN JapaneseLake I7 8800K
zacky1223
Oh ? what's this Japaneselake ? LOL sorry kinda noob. I always go for I5 though. I made a mistake previously buying the overclock version. In the end i never oc. hahaha
ZrE0_Cha0s
well i still think that u can wait for next gen if u can
evildoctor
Your Current CPU currently in what Gen? Upgrading for the sake of getting new things? If your processor is currently in 4th Gen, then maybe you should don't upgrade until your CPU spoil. Cause there isen't really much improvement over the past few generations. Intel has been focusing on mobile side of processor instead of desktop processor. Suggest you should go for a new case instead.
zacky1223
well we aint sure when coffeelake will be out but if they(intel) say next year means next year. :o
At least buyers can use the term "let's go grab a coffee" +1 selling point for Intel
Thanks guy for the recommendations :) Mine is the 3rd gen. I5 3570K. Just not sure if upgrade liao the speed will increase much ? If minimal then I just use till spoil hahaha
Elijahonli
i think we really need a sticky thread about the performance "increase" over the older generations cpus....
