Need help for new pc
itnoobieee
Hi all, need help building a new pc. Budget around 2k inclusive of a monitor,hopping to get 1440p if possible. need wifi in case cant connect to lan cable - portable vs built in?which one is more stable? Any case will do as long as dont over budget...
Not a hardcore gamer, but like Sims game with tons of expansion packs and custom items ...i know this sounds lame...
Mainly use the pc for video and photoshop editing, movies and some simple microsoft office stuffs.
hope to get something that can last longer, at least for the next four years.my bro did recommended the rig for me, but he doesn't really know that much and myself have no ideas how does this combination looks like.....
are these sufficient? or any other recommendation?
asus prime b250m-k
i5 7400
gtx 1050ti 4gb
wd blue 1tb
fsp hexa +80 550w
gigabyte gtx1050ti 4gb
tecware f3 case
kingston 2133hz 8gb ram
better to get a pre-built or build own rig? any thoughts? thanks!
shiroyuki03
Would suggest you to go for Ryzen cpu. definitely ownself build is more fun and you can get to customise every part of the system.
singupingu
CASE: Tecware F3 Elite $55
MOBO+CPU: Asrock AB350M PRO4 + Ryzen 5 1600 $453
WLAN: TP Link Archer T6e $54 via Dynacore
RAM: Corsair Vengeance LPX 3000MHz 16GB Kit $225
PSU: Superflower Leadex Silver 650W $129
SSD: PNY CS1311b 256GB $135
HDD: WD Blue 1TB $72
GPU: Galax GTX 1070 (promo price) $619
OS: Windows 10 Home $12 via Carousell
MONITOR: http://forums.hardwarezone.com.sg/graphics-display-bazaar-200/hp-elitedisplay-e272q-27-qhd-monitor-5653936.html
TOTAL: $2049
Prices quoted from PC Themes or otherwise stated.
Prices above are SRP and it's not subjected to any kind of discount yet.
You can try source GPU and RAM at Amazon or Carousell (if you don't mind 2nd hand) to fit the final price to the budget.
Sent from PM me if you wanna build a DIY PC or wanna learn how to make one yourself :D using GAGT
gld998
asus prime b250m-k
i5 7400
gtx 1050ti 4gb
wd blue 1tb
fsp hexa +80 550w
tecware f3 case
Gtx1050ti and 1440p? Mai la mai la... chao chao gtx1070
Sent from Samsung SM-T719Y using GAGT
