Need help for Nvidia 970 GPU
botwriter
Do you guys see the oculus rift standard full experience requirement? It requires nvidia 970 GPU
planning to buy a laptop with that GPU, is it exist? Or must it be desktop?
heard that 970 and 970m is different, how to buy laptop that can support full experience for oculus?
trento
a comment on Reddit.
I have mainly ran my own applications on this laptop with the dk2. These are big projects which I made so that they ran 100% smoothly on my laptop. It depends on the game you want to run to get 75fps I guess. As for your question; Is it actually capable of outputting 75hz? yes. 120hz, I don't know yet, but I wouldn't know why not. Just make sure you set the GTX970m as main GPU for all applications.
botwriter
hi trento, but my friend said that 970m and 970 is different. Can 970m run as smooth as 970?
muddle
From their official press release:
Your system will need at least eight gigabytes of RAM for the Oculus Rift, and you'll also want to make sure that you have an HDMI 1.3 connection to your desktop (which your high-end graphics card will undoubtedly have). You'll also need two free USB 3.0 ports and, it almost goes without saying, but you'll need to run at least Windows 7 SP1. (By the time the Oculus Rift hits, you'll likely have moved on to Windows 10.)
As for laptop users, it's likely that the HDMI bit is going to make life difficult. As Oculus Chief Architect Atman Binstock describes in a blog post, the HDMI requirement is a little more complicated than just "the laptop needs an HDMI port."
"...many discrete GPU laptops have their external video output connected to the integrated GPU and drive the external output via hardware and software mechanisms that can't support the Rift. Since this isn't something that can be determined by reading the specs of a laptop, we are working on how to identify the right systems. Note that almost no current laptops have the GPU performance for the recommended spec, though upcoming mobile GPUs may be able to support this level of performance," he writes.
From the last paragraph it seems that laptops are currently not recommended even if they meet the hardware requirements. This is due to the way they are connected in a laptop.
ondooy
no, it's like buying a coke can and coke bottle.
both are coke but taste different... :s13:
