hi all... my pc has been giving me problems recently... it will somehow hang during usage (can be while surfing or watching videos). when it hangs, even ctrl + alt + del doesnt help. only a hard reboot does.
usually after that, i may encounter one of the following scenarios:
1. "non system disk error" (can be "solved" by turning off pc, turning off switch, wait for a while, and after that it manages to boot up as per normal again
2. fail to get pass bios, auto power off whole pc and retry to start all over again. (forever loop)
i initially suspected that it's the ram. so i did a memtest. however, the results did not show any problems.
can it be caused by motherboard? or PSU?
my setup are as follows:
Windows 7 Professional
Intel Core 2 Duo E7400 & Gigabyte EP43-UD3L
Kingston ValueRam PC2-6400 DDR2-800 4GB (2X2GB)
PowerColor HD4850
Intel 320 series 160gb SSD
WD Black 2 TB
WD Green 1.5 TB
LG SATA 22X DVD Rewriter
Andyson 480W
anyone able to advise?
)2. fail to get pass bios, auto power off whole pc and retry to start all over again. (forever loop)
PowerColor HD4850
WD Black 2 TB
WD Green 1.5 TB
Andyson 480W
