sophialao03
- Jan 26, 2016
My son just finished "N" levels and I wanted to find out if he can jumpstart to "A" levels. Need advice...
HI, yeah I had a discussion with another parent and Yes, there is a small possibility that my son can go to A level, however she mentioned Insworld Institute.
They said my son can take IGCSE instead for 18 months or less. Any idea about IGCSE?? or Insworld Institute??? Thanks
A Levels is a very tedious syllabus that (not many but there are) O levels have difficulty coping with the fast paced environment. Things you study in O levels will be very useful for A levels, and since O levels is a build up from N Levels, it is not advisable to jumpstart to As -- in addition, if he didn't do well for As, may end up in private uni / poly instead. (just my 2cents worth)My son just finished "N" levels and I wanted to find out if he can jumpstart to "A" levels. Need advice...
