Hi guys currently i hv a Panasonic Lumix G Vario 14-140mm lens (Micro Four Thirds System) but i want to use it on my Nikon DSLR D3100 camera,is there any adapter for it as i try searching on the internet but to no avail,tia![]()
That's not possible. You cant adapt ur MTF lens to F mount (Nikon). What you can do is adapt F mount lenses to your panasonic body.
Nikon DSLR are not really adaptable.
You will have more choices with Sony.
Dun think any makers will want to make such an adapter.
Micro43 lens has a shorter flange focusing distance, you cannot cross adapt onto dslr unless the manufacturer makes an optical adapter. And that is provided the lens does not have a very protruding rear recess. And with electronics now controlling focusing etc, end up needing a complicated electronic adapter. And the fact that the image circle of an M43 lens is smaller and might not cover the bigger D3100 sensor..
Oh ya i forgot i got another camera Sony A7II,does it have an adapter for this panasonic lens ?
