need help in building new rig /computer fault
Hoo123
Hi, guys need help in building new gaming rig budget around 1k-1.3
another problem is my com , just hang yesterday on the monitor it show reboot or press anykey to reboot. what the main cause of this my ssd give way?
MoneyFace =p
What SSD is that? I've also been facing similar issue with my MX100. :(
Try shutting down completely and turn on after a couple of minutes.
voltech
Hi,
you might want to state the problems you faced and list down your PC specs for other forumers to see. I would suggest you to wait for other forumers to help you with your problem before proceeding to purchase a new system.
Hoo123
i have been shutting down and restart yet the problem turn out worst , after i switch on a fews second it restart and keep on restart every few second.
Hoo123
i thinking of choosing haswell cos have been reading in the forum skylake will be quite ex and exceeding my budget
voltech
From what you are saying. Can I check is it when it is at the windows loading screen, it would automatically restart? And it repeats the whole process from there?
If it is, there is a possible chance that your Operating System is corrupted.
monikernemo
Huh?
Skylake is expensive now because the locked chips are not released yet. Once the locked chips are released, should be as cheap as haswell.
However Haswell maybe even more inexpensive as they may try to clear remaining stocks
Sent from microwave oven using GAGT
Hoo123
need a new monitor , keyboard and mouse not need, maybe ssb will use from my old com
Goodshot
Actually haswell 4460 + h81 board = $320+ already can handle 99% game . u just need a powerful gpu like 970
