Need help in choosing GPU
homeyyy
Hi guys, I recently started playing TERA Online and GTA V on my pc and my GPU fan seems to be running at 100% and its super loud + scary.
My specs are i5-3470, 8GB RAM, GTX 550Ti.
Can you guys recommend me a new GPU thats max $250 that fits my pc? Thanks!
avsquare
$250 is quite thin. Depends on what settings and reso you want to play on GTA V cos that's quite a resource hogger.
homeyyy
I'm looking at this Sapphire dual x R9 280 3GB on lazada for $275 w/o Mastercard Monday.. Is this worth the buy?
Sent from Sony D6503 using GAGT
undead102
Just for your info. R9 270 can play gtaV at very high settings at 1080p no problem. Just off all AA will do. Feels silky smooth. Use latest amd 15.4 beta driver. Game is very well optimize.
trento
Get 280. I have the card. Can overclock like hell. Of cos, will generate more heat too. 285 is cooler, but also more ex
homeyyy
But thing with amazon is i heard its no warranty which is kind of scary for electronics.. @_@
