need help in fixing pc problem.
peppermint03
pc problem : x58a-gd65 and evga gtx680 4gb compatibility problem?
okay i tried to boot up the pc but there is no display no beep but led, fans all running and there are 8 phrase power.
usb also not working. i then put in one ram and it has display. but stuck at splash screen. only can see this screen.
any people know what happened?
it is stuck at this screen forever!
anhyeuem
is this a DIY PC or stock from maker?
what do you mean put in 1 ram?
jtjt00
TS, list down all parts of your desktop here.
peppermint03
this is ownself diy one. i mean im using one stick to test. if fan can on, motherboard on 8 phrase power, got display, got power. what thing might be causing my pc to stuck at splash screen leh?
peppermint03
nv put in hard drive. cant even get past first stage of post. keep stuck at this screen. took out all the usb device also the same.
anhyeuem
ok u mean 1st time no ram installed then u boot up?
then 2nd time put ram and then boot up?
I suggest you put in all components now, instead of one by one.
and like someone else mention list down all specs of parts.
it could be some parts are not compatible.
also what connectors are going into each component.
Like example harddisk needs power and data cable...
anhyeuem
no hard drive then how to boot up???
you 1st time DIY is it??? Then its better you search youtube on how to DIY and install all parts 1st because there are simply too many things going wrong now...
you can see from video on how to install CPU, CPU heat sink, what cables going into and out of motherboard...etc.
peppermint03
btw thanks all of you guys for helping me. :D
ya when i did not install ram. the pc goes on a eternal reboot.
when i install the ram it is able to boot up.
i put in all the components already. still weird not working.
im going to change my cmos batt tonight.
btw i did took out the battery and clear cmos.
peppermint03
if i dun have harddisk. then it will goes into the screen where it will ask to insert bootmgr.
problem is now stuck at the picture i posted. cant even go into bios menu.
anhyeuem
why do you want to go into that screen?
some particular reason you don't want to boot to desktop?
peppermint03
nono. i mean i cant get past this screen, thats all. it freeze at the splash screen or rather the same as this. if i cant get into bios meaning i also cant boot into window ma. heh
Xilantu
isn't this screen before windows actually boots of your drive? different bios have different keys to go into bios. some are f2, some are f12 and some are del keys. just keep spamming any of the keys mentioned when you restart i guess.
peppermint03
no eh. this is the first stage of POST. not the 2nd stage of POST. usually after this screen then can enter bios.
peppermint03
manage to get into bios after resetting bios.
memtest on ram is okay.
on bios able to find cpu. running at good vcore 1.104v
power on motherboard, looks good as well.
graphic card should be good. since able to see monitor.
bios is 22.3
i heard it somewhere flashing new bios will help.
but for msi x58a-gd65. this is the latest already!
is there anything i can do? or just upgrade the cpu? thank you.
after removing the battery overnight then im able to get into bios. after that. i will get back to the same screen i first get. hang there forever...
is this a case of graphic card and motherboard compatibility problem? like my mobo cpu too old? lol
