need help in ios functions before switching from android
childish_67
Hi guys , have queries abt ios before switching over from android :
1) can we send mp3 or music files.through watsapp?
If cant, any 3rd party that can help?
2) if we wish to transfer mp3 or music to ios, is itunes the only way?
Any 3rd party software that can do copy n paste from pc to hp like windows or android?
3) photos can just copy n paste without itunes right?
Thank u very much
tec_geek
Thank u very much
1) You can only receive music files via WhatsApp but not sending out unless it's not in the default Music app.
2) iTunes is currently the only way but there are several third party softwares that are allowing you to 'manually' transfer to iOS.
The disadvantage is those softwares needs to be purchased to unlock the feature to transfer large and huge amount of music.
3) For photos, not sure if the above mentioned third party softwares can do it but, the only way is iTunes. And it's the fastest as well.
Have a primary folder in Windows Explorer or Finder so that iTunes can locate where to get these photos.
Then collate the pictures into another folder as based on albums, then put these 'albums' in a primary folder.
In iTunes, select the primary folder. After which, you can manually select which are the 'albums' you want to sync to your iOS device or select all the 'albums' in the primary folder.
childish_67
Thank u very much ☺
I guess i may not purchase iphone unless i can solve how to be able to send mp3 through watsapp
