Need help in Rig - 3d rendering / office purpose
sparksue
Hi Guys,
I need some helps on this.
Recently helping company to config one 3d rendering system.
Went down to Sim Lim and ask for reconfiguration.
Just keen to know whether is this good enough to do intense 3d rendering with vray included?
Thanks!
Here's the following spec:
A;
ASROCK H87 PERFORMANCE + I7 4771
PC 1600 MHZ DDR3 CL11 8GB x 2
SANDISK SSD 128GB
WESTERN.D 1TB BLUE 64MB SATA
LG DVD-RW
LT NVIDIA QUADRO K600 1GB
SEASONIC 620W
C.M 311 ATX CASING
Window 7 Pro 64Bit
Overall pricing : $$1773
P.S: I notice about the latest SSD for C Drive. But is it really useful? Also I notice that sim lim square people are actually recommending Quadro as a graphic card for rendering / design purpose. Is it true?
Will it work well with other program like Adobe software / Autocad / sketch-up program?
Or is there any other good fig other than this?
My budget is around 1.9k - System + window 7 pro.
Appreciate anyone can give advice on this? Thanks.
:s12::s12:
royfrosty
Hi Guys,
Thanks!
A;
SANDISK SSD 128GB
LG DVD-RW
SEASONIC 620W
C.M 311 ATX CASING
Window 7 Pro 64Bit
:s12::s12:
If you are gonna set up for coy. Best is ask your coy to go thru proper channel and go thru corporate deals.
Get OEM PC type as they will have tech support for your coy. DIY is not a way to go for official use.
Ark Law
Better off asking your company to assign you as lead negotiator for engaging an OEM partner to spec-out new PCs in your office than getting DIY. DIY not suitable for corporate environments, especially when users need warranty service and support
Ark Law
Hoot apple ? :o
Anyway, what I see in my office, the main OEM is Gigabyte :o
sparksue
Thanks guys for the advice.
Actually I check with my boss about it before I went to sim lim and he did ask someone to get the CPU but when i went to the store that he purchased, the guy don't seem to remember him...how ah?
And the spec i based on is actually given by him as well. Is it good enough if like say my boss don't really keen on those OEM PC type - He just keen to getting one at the moment since my understanding is that we are moving the place by next year so we might go for 'stand-alone' type of system first which we will transfer our document through email / thumbdrive.
I might have to check with him again since i just start my new work today..lol
Any further advice will be good. you mean those store that's also able to have a package that cater both system purchased and service (etc. networking / transfer data within company)
Also not sure am i the right person to talk to him...it's like 2nd day ask him to look for those OEM PC type...funny lei..lol
sparksue
Autocad... do you need a i7?
I7 - I am using it for 3ds Max / Vray so I think it's should be powerful cos I might need a fast render machine and the given budget allow me to go for I7.
Plus I guess currently rendering - 16GB Ram should be more than enough right? Or does window 7 pro / 3ds max program able to handle more than 16GB, thought of getting 24GB (additional 8GB)
Advice need. Thanks!
sparksue
must be small firm right?
my coy need any custom com , they call dell
yup,
Currently only 3 designers, and i am included so i dont think he will be keen to get those OEM partner..but i know now abit OOT.
Just curious my current spec that i mentioned should be okay right?
Able to withstand at least 2 years of works?
