Need help in SSD Mobo + CPU
ayuluv
Hi pros
I have been mia for pretty long and kinda lost touch.
May I know do you have any good recommendations on a good 1TB SSD with affordable pricing level
And currently I am using i7 3770k if not wrong and my mobo started to have bios issue where it gets stucked frequently
May I know if I were to stay with Intel, which mobo and cpu combo should I go for?
Need at least i7 due to some multi tasking needed for my business.
Thanks in advance
ronnie_gogs
I moved from a 3770k to A AMD 2700x last year. It was totally an upgrade at price less than the original 3770k.
Currently new Ryzen was just launched and 3600 and 3700x should suit you fine. SSD wise I have stuck to Samsung SSDs. I have a Samsung 860 Evo 1tb and 970 Evo NVME Samsung 500Gb as a boot drive. Mother board is a Asus ROG Crosshair Hero VII but you dont need it as its overkill if you don't overclock IMO.
Rashkae
If you are doing multitasking, then you shouldn't look at Intel right now
ayuluv
Thanks mates for all the awesome replies
Seems like AMD is highly recommended.
I had stopped using AMD after 955 series era due to pin issue
Are the newer ones fine ?
Phen8210
the new ones got a bright future..
3600, 3700x and 3900x have amazing value
ayuluv
Thank you so much mate.
Guess it's worth a try and jump back to green camp haha
BTW can the 570x mobo use 3770k ram?
I think seems like no issue
And is there a good casing as I am still using a lian li 70b or something like that
A full tower with a door in front.
Or should I just use it since it is still working fine just about 10 yrs plus old
3700x lo since u are from i7 side, ram u need to get ddr4. Nvme ssd can get adata 8200. Casing can reuse if u wanna save money or no special requirements like bling bling
Sent from Rem Is Best Waifu using GAGT
ayuluv
Thanks alot for your sharing mate
Yeah no need bling bling now
But I know new Lia li cases are nice haha
ayuluv
btw may i know if the 3950x is released, will the current Ryzen 9 price be affected or reduced slightly?
ayuluv
oh awesome. In that case I believe i can go ahead without waiting for the release of 3950x
Thank you so much for all the help rendered
Sincerely apprecaite!
Koenig168
welcome :), though you might wish to wait. The 3950X is supposed to launch on 7 or 9 Sep which is just a few days away.
ayuluv
Ah thanks alot
Yeah maybe it will be my post bday upgrade for me
Thanks alot mate for sharing your views ya
BTW my current seasonic 650 gold plus and my corsair should be able to do their job if I upgrade to the ryzen 9 series right?
Current look I need to change mobo, cpu, ram, ssd
Cheers
Phen8210
Ah thanks alot
Cheers
yea also one more thing.. nowadays the value of board is in the vrm..
If u getting a b450, msi tomahawk max is a good choice. for x570 it's gigabyte auros elite. Both offer good value.
I've seen many people that upgrade did not put consideration on this factor... so might as well let you know..
For ram u can consider 3200 c14 or 3600 c16.. both provide good performance along with use of ryzen 3000. if u find local ram too expensive consider newegg or other international shipping market.
ayuluv
Awesome!
Thanks alot mate for your sharing.
Yeah am more inclined to auros x570 elite even though the review at tomshardware is low due to no USB c and debug led which I believe is not an issue.
And locally Pro version have WiFi which I don't use since am using Asus ac88. Hence kinda wasted.
Thanks for the heads up!
As for ram I might consider gskill series but have not really check it out. Should be trident neo or something like that if not wrong
ayuluv
Thanks alot for sharing mate.
Very good price too and rating!
