Need help in upgrade/build pc
iNoStandard
Hi guys,
I need some assistance in upgrade/build my pc, playing Dota2, Ragnarok Online and some light editing/rendering .
Reason: Intend to upgrade since most of my parts quite old already
Budget: 500-800 exclude gpu if needed
Ryzen 5 2600 to ?
Should i upgrade the Motherboard ?
Ram : 16gb should be enough ?
Gpu : not intending to upgrade at the moment since still usable and doesnt affect much in my games
Current spec :
Ryzen 5 2600
Msi b450 tomahawk
Zotac Gtx 1060
Ram : 12gb ( 8 + 4 )
Koenig168
MB is fine.
The RAM should be 2X8 GB of DDR4-3200 or 3600. Suggest you sell the existing RAM and get 2X8 GB instead.
As for the CPU, seems adequate to me. You can upgrade to Ryzen 3600 or 3300X but don't really seem worthwhile unless you need very high FPS at 1080p.
The one thing you should upgrade is to get an SSD for the OS and games.
iNoStandard
MB is fine.
Any recommendation for ram ??
Ryzen 5 3600 seems to be the best for me right now but im afraid there will be a new one coming up soon as per linus tech tips, should I wait for it since im not in a hurry
my current window 256gb ssd
I will be purchasing at least 1TB ssd for storage, saw a 1TB crucial for about 160-170$ online
Koenig168
No particular RAM in mind at the moment, perhaps some other HWZer can chime in.
For the SSD, suggest you get the WD Black instead as there is presently a great offer at S$190 for the 1 TB version.
https://www.amazon.sg/Western-Digital-WDS100T3X0C-BLACK-Generation/dp/B07M64QXMN/ref=sr_1_4?dchild=1&keywords=wd+black&qid=1591412719&s=gateway&sr=8-4
NightRaven49
not sure why u think this way but gpu is the determining factor in game quality. anyway ur cpu is still viable for both gaming and editing work. and like koenig said get dual channel ram, crucial ballistix and corsair vengeance lpx seems to be quite popular nowadays.
iNoStandard
I understand, currently i am not experencing lag or drop in fps but will be upgrading it in future.
Yea the corsair vengeance is popular , 8x2 gb 3600 close to 200$ And 2666 150$ . I should be going for the 3600mhz
iNoStandard
NightRaven49
huh siala so ex ah, where u buying from? lazada selling 2x8gb 3600 for $150, official store with lifetime warranty. for ryzen 2nd gen i think 3200mhz is enough though, was considering getting the crucial ballistix 3000mhz one on amazon for about $115, then oc to 3200.
minuteez
Since you not really having issues, I'd say wait for next year when new toys come out. Then build a new rig with r7/r9 instead. Should last you 5-7 yrs then? Excellent for editing also
With the incremental upgrades you wanting to make now, you will see some improvement of bout 20-30% when editing? Gaming not much diff, since currently, you not having fps issues so maybe graphics can bump up more and look nicer a bit, but the gpu will gimp how much you can push the graphics anyway.
If you do decide to upgrade now, make sure to get a cooler. Cheap one enough. The 3600 stock coolers cannot make it.
Anarky
destiny88
Just change ur ram. Seriously ryzen needs dual channel. But be warn if u r using 3600 ur ram speed supported is listed max 3466mhz. U get 3600 mhz now might need to down clock it. But future proof is fine. I just brought 3733 for mine and it refused to boot for any speed above 3400.apart from that tune your ram speed using ryzen ram calculater. Alot of videos on YouTube. Apart from that I think 1060 is fine for your use, can wait for rtx3000 series or upcoming rdna2 amd cards.
iNoStandard
no idea, that was the last time i see in lazada , maybe the price dropped or i saw wrongly
yea currently there isn't much issue , so i should wait for new ryzen to be out ? 20-30% improvement not that great .. don't wish to upgrade it again within the next few years
https://www.amazon.sg/gp/product/B083TRRT16/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
Why don't you just get these for SGD104.36 + SGD2.99 for Amazon Prime. Don't even need to OC
this is really a good price , thanks ! saved like 50$
yes, my current max is only 2933mhz for ryzen 2600 , so conclusion , i can upgrade my ram & ssd first than wait few months
hafiz116
As of now the only upgrade you MUST do is upgrade the RAM. Not sure if anyone has 3600Mhz working on a B450 Tomahawk but if you do please advise so the TS can decide between 3200Mhz and 3600Mhz RAM.
Everything else you should wait for new stuff to launch. Reason is simple, even if your not going for the high end stuff, whatever your eyeing up now will drop in price when there is a lot more newer options available.
minuteez
Go with what you comfortable with. We just throwing options to help you make informed choices. :s13:
But yeah, Id say if theres no pressing need, just put up with the rig until we get more info on next gen Ryzen. Build up the war chest for major revamp.
Prices a bit inflated at the moment too since supply chain affected. Wait for things to stabilise.
I would have suggested get a game console instead if gaming are your concerns but that also not a good idea now. New consoles coming out in like a few months time and Nintendo Switch prices are WWAAYYY inflated at this time.
Unclemun
an i5 7th generation cpu is decent.
the upgrade using $600-$800 will not see much improvements and selling old parts would not get you much back as you will have to sell as a pair.
For memory - are you using at least 6GB of it? If you are, can you just add 8GB and be done with it without changing the mainboard?
I would recommend changing GPU only and keep CPUs and mainboards for 5 years.
iNoStandard
Ok , i have just made a purchase of the Corsair Vengeance LPX Ram DDR 16GB PC 3200Mhz under shopee .
Now shall wait for new processor to be release
didymus
Hello..
Wanna assemble in PC themes for PC upgrade.. but since its closed till Phase 2...
Any idea who can help to assemble? :p
