Soundaholic92
- May 27, 2012
Hi guys. I bought a MasterLiquid Pro 280 about a week ago. After a few days there was a lot of clacking noise from the cooling block. I just adjusting the pump/fan speeds and give it a few days but they problem didn't go away. Is there anything I can do to fix this or is the unit faulty and I should just get an exchange/refund?
For info, the two 140mm fans are connected to the CPU fan header using a provided 4-pin splitter, and the cooling block is connected to the OPT (optional?) CPU fan header. I tried having the pump run at maximum power or the default power, and the fans at quiet or normal mode, but all combinations still produce the clacking noise. Temperature-wise it's actually doing ok. I'm getting 30~35C during idle and <70C during gaming.
