Need Help on a 1.2k Gaming PC!
MP4Craze
been lurking here for sometime now, and its finally for me to assemble a PC!
Hope bros here can help me out.. i play mostly L4D / Dota / sometime GTA5
possible play all this with a budget of 1k ? cos 200 for monitor
i do not need mouse and KB, just the CPU and monitor.
i see many brothers here say tradepac is the cheapest... possible to get all the parts from there including OS? cos i cant buy online... wanna let them install for me once and for all..
This Saturday i will be going down liao! Thanks in advance..! :o
kamishikome
hi i have been on this forum for quite sometime , always take and never give. cause i dont think im knowledgeable enuff. this is my first build anyway, feel free to give opinion!!
CPU+MOTHERBOARD: i5-4460 3.2GHz Quad-Core Processor + ASRock Fatal1ty H97 Killer - $403 (tradepac)
Graphic Card: MSI GTX 960 2GB $ 325 (tradepac)
Memory : kingston pc3-1600 DDr3 8 GB -$60 (tradepac)
HDD : Western Digital Caviar Blue 1TB $72 (tradepac)
PSU : Seasonic non modular 620W $ 99 (PC theme)
total : $ 959
i didnt include SSD and case because i think you need to choose to have SSD or not . And the design of case you want
CASE : the rest of your budget !!
kamishikome
Anyway this build should be able to run any game at 1080p at very good settings and frame rate. personally i play witcher 3 no problem at all.
MP4Craze
total : $ 959
total : $ 959
Thxs bro!
can i save abit from a lower end motherboard? so i can get a ssd? and also if i go for radeon graphics will be higher spec?
ur recommendation got no OS :(
DawnsTear
[Mobo&Proc] MSI H81M-E35 V2 /w i5-4460 - $342.00
[GPU] Sapphire R9-380 Nitro 4096MB - $365.00
[RAM] Kingston DDR3 1600Mhz CL11 (8GB*1) - $67.00
[HDD] Toshiba 1TB/64MB - $66.00
[ODD] Samsung 24x DvD+-RW - $25.00
[PSU] FSP Aurum S 500W Gold 80+ - $89.00
[Case] Coolermaster N200 - $61.00
[OS] Windows 8.1 Professional 64bit OEM - $33.00 (G2A)
[Monitor] Dell 23" S2340L - $199.00
Total :- $1,247.00
Optional
[SSD] Crucial BX100 250GB - $139
Total :- $1,386.00
Buy from PC Themes unless stated otherwise.
MP4Craze
Total :- $1,247.00
Optional
Total :- $1,386.00
will they allow me to give the the OS key and they install for me? :o
Goodshot
R9 380 not enough to run gta5 smoothly ba , $1000 budget the most is I5 + H81 brand-new and used gtx 770 $250 , I won't buy brandnew lousy gfx if I m low on budget . Btw a lousy $60 psu can't power up AAA title game for long
DawnsTear
Maybe.. they may charge u for Assemble and Installation of OS
U save ard $100 buying from G2A, make sure u tell them is Windows 8.1 Professional edition.
Or u can get the whole system from Fortran, not sure he still ard or not.
DawnsTear
R9 380 should be able to run smoothly on High - Very High @ 1080p and how is FSP Aurum S 500W a lousy PSU ? :s22:
If TS can find R9 290 or R9 290X, that will be a better choice.
MP4Craze
think i will be going for new ba.. will try to get the ssd ... stretch the budget abit
i try looking at the G2A win8.1 ... seller from spain? can buy? any kind bros can give me link? :D
kamishikome
Thxs bro!
opps sorry.. but i see you figure out the OS problem.
