Need help on a budget PC
thepoorkiddo
Hi all,
My 6 year old PC broke and i'm looking to build a budget PC, hopefully under 1k, for some light gaming (dota, left 4 dead, etc mostly old games), web browsing (with many tabs) & watching movies. Managed to gather this much from PC themes & other threads (probably will just shop at simlim & assemble at PC themes) and could really use some advice:
1) CPU - total noob here, any recommendations?
2) Motherboard - total noob here, any recommendations?
3) GPU - not sure if i need to get one for those above mentioned games?
4) Ram - G.SKILL RIPJAWS V 2666MHZ CL15 ( 4GBx2pcs ) SGD 89
5) SSD - SAMSUNG EVO 860 250GB 2.5" SSD SGD 89
6) HDD - WESTERN.D 2TB BLUE ( 5400RPM ) SGD 85
7) PSU - SEASONIC M12II-MODULAR 620W SGD 115
8) Casing - SHAR KOON TG5 ATX ( White , Blue , Red ) SGD 89 (any other good airflow budget case to recommend?)
9) Windows - how much do these go for nowadays?
TOTAL: SGD 467
Might add in my old HDD (WD 2TB green) if it ain't broke so i'm not sure if the power supply is sufficient considering if the external GPU is included.
Much thanks in advance!!:s12::s12::s12:
thepoorkiddo
Thanks!
Quick question, I actually have an old GTX 670 2GB, not sure if it's better than the integrated Ryzen 2400g.
Koenig168
GTX 670 is definitely better, around 33% for CS:GO 1080p.
joventay
I suggest you go for a Ryzen 2400g build and skip the GPU. There is a discussion in this thread
https://forums.hardwarezone.com.sg/hardware-clinic-2/need-help-budget-build-6021149.html
according to the recommendations given
Summary
(1) CPU: Ryzen 3 2200G + MB: Asrock B450M-HDV (bundle from tradepac SGD225)
(2) Reuse HGST 4TB and HGST 1TB HDDs
(3) RAM: G.Skill RIPJAWS V DDR4 2666Mhz CL15 8GB (4GB x 2pcs) - $89 (PC Themes)
(4) PSU: EVGA 500 BV 80+ BRONZE 500W PSU - ($67 from tradepac)
(5) Casing: Option 2 (Reuse DVD writer):
Fractal Design Focus G Mini Window - $75 (PC Themes)
for windows, just go to lazada and buy the product key.
cost u 20sgd n less.
thats what i am going for .
since u got more budget than me, you add in the cost of SSD and HDD and change cpu to 2400G and add another GPU.
thats about it i guess.
joventay
another thing is from my past experience, tradepac is cheaper than pcthemes if you know what you are getting.
my existing built 80% from tradepac and my pc is built by pcthemes for SGD30 many years back.
thepoorkiddo
how does the windows from lazada work? they will send you only the product key or the cd as well? sorry total noob on that.
thepoorkiddo
Summary
can't seem to find the above in their price list :x
bobozhang137
Hi all,
TOTAL: SGD 467
if you are looking to maximize your budget
this is the build that i would recommend you (based on dynacore pricelist)
CPU and MOBO - Ryzen 2600 with Asrock B450M-HDV - 377sgd
RAM - KLEVV BOLT X 3200MHz CL16 2x8gb DDR4 RAM - 155sgd
SSD - 240gb wd ssd - 60sgd
PSU - FSP 600W PSU - 70sgd
CASE - CM Masterbox MB510L - 74sgd
GPU - PowerColor RX570 4Gb Red Dragon OC - 220sgd
OS - Windows from lazada - less than 20 sgd
total of 976 sgd. When you buy windows from lazada they will give you a cd key that u need to activate by yourself.
This 6 core 12 thread build will allow you to play all old games and even recent games at 1080p decent fps. Best part is that in the future if you want to upgrade your pc u can just change your graphic card and chances are that it will not be bottle necked.
If you want to budget your build
Heres another recommendation for you also based on dynacore price list except for ram
CPU and MOBO : Ryzen 2200g + ASROCK B450M-HDV : 240sgd
RAM : 2x4gb HyperX FURY DDR4 2666mhz : 69sgd
PSU : FSP 600W : 60sgd
SSD : WD 240gb : 60sgd
CASE : CM MasterBox Q300L : 59sgd
OS : Windows from lazada (Less than 20 sgd)
total of 508sgd
You will be able to play games like dota,csgo,league of legends at medium to low settings at decent fps, even fortnite is playable. Dont expect to see frames above 100 for this build though. This is the kind of build that you build if you are the kind that plays dota2 once a week or so and watch netflix plus surf the net.
SkyShroud
i believe is cheaper to buy ram from newegg
also, juz becoz there is gst doesn't necessary means have to pay gst, gotta checkout to cfm
-Synchronicity-
@bobozhang137 For ts usage and budget, no point going 2600. Furthermore, the PSU you recommending to pair with 2600 is sufficient for maybe a super slight overclock. Don't forget due to precision boost, the cpu will still "auto overclock" which might cause issues when you use a crappy 600watt psu. Also don't forget that this is am4. Ts can choose to upgrade cpu when new chip which supports am4 socket is released.
@ts Just stick with 2200g or 2400g would be good enough for your usage. The PSU if you wanna add in your gtx670, gotta use around 600 watts which imo is not worth it if you are just on those games as 2400g is good enough for those.
thepoorkiddo
Thanks for all the advice. Have shortlisted based on the recommendations and should be going for Ryzen 2600 if it is only a slight top up (based on price list <$20) but not sure if there is any major differences between ASROCK AB450M HDV & ASROCK B450 PRO4? (i read like more ports or something?)
1) CPU & motherboard - Ryzen 2600* ASROCK AB450M HDV SGD 319 or ASROCK B450 PRO4 SGD 383 - tradepac
2) GPU - GTX 670 (re-use, if not broken)
3) Ram - G.SKILL RIPJAWS V 2666MHZ CL15 ( 4GBx2pcs ) SGD 89 - pcthemes/tradepac (need to ask one?)
4) SSD - SAMSUNG EVO 860 250GB 2.5" SSD SGD 87 - tradepac
5) HDD - WESTERN.D 2TB BLUE ( 5400RPM ) SGD 85 - tradepac
6) HDD - WD 2 TB Green (re-use, if not broken)
7) PSU - SEASONIC M12II-MODULAR 620W SGD 110 - tradepac
8) Casing - SHAR KOON TG5 ATX ( White , Blue , Red ) SGD 89 - pcthemes/tradepac (need to ask one?)
9) Windows - Lazada windows 10 $9? (based on google)
My worry is whether the PSU of 600W is sufficient or do i need to get more to be safe?
-Synchronicity-
See the problem is if you commit to this and your gpu dies, you basically have a brick as only 2200g/2400g comes with in built gpu. So if you buy a basic gpu like the rx 560, it could set you back a further 100-150 bucks.
You will also see 0 improvement as your usage is really light. Also, the cpu can be upgraded at any time as long as it supports am4 platform. So you could literally just remove the cpu and replace with a 3xxx or 4xxx ryzen cpu in the future.
As for the board, yes it's the ports.
For PSU, what matters more is quality of the PSU, not wattage. Though 500 is fine for your built if you don't have gpu + some overclock or have a gpu but not overclocking either cpu or gpu. 600/650 is recommended if you want to overclock + have a gpu.
averdant
ASRock B450 Pro4 has more features like ports etc, and is better for overclocking due to better VRM.
But ASRock B450M HDV is fine if you're not going to overclock, or if you only intend to overclock lightly.
Your build will probably use around an estimated 400W+-, so 600W is enough.
https://outervision.com/power-supply-calculator
You need to go high tier PSUs when you want to overclock, you can go lower tier PSUs when you don't need to overclock but don't get those unknown brand non-80+ PSUs. Not to say that just because the PSU comes from a known brand eg. Coolermaster or is 80+ means the PSUs are of good quality but it's just a baseline for you. Brand names can come with shitty quality 80+ PSUs too.
https://linustechtips.com/main/topic/986897-psu-tier-list-21-legacy/
One thing to note is that when two PSUs share the same model name, but different watt versions eg. 550w and 750w versions can end up using different grades of components putting them in different PSU tiers.
thepoorkiddo
Thanks guys for all the input!!
Decided to go with 2400g as recommended. Hopefully my gtx 670 stays strong. :p
Albertphoon
Hi all,
TOTAL: SGD 467
Why not do a troubleshooting and see which part is spoiled then decide.
If near on place maybe I could help you . Free
SkyShroud
ram performance matters a lot for amd
Quick check - Higher the better
2666 / 15 = 177.73...
3000 / 16 = 187.5...
3200 / 16 = 200..
Proper timing calculation - Lower the better
2x15 / 2.666 = 11.25...ns
2x15 +3 / 2.666 = 12.37
2x15 +7 / 2.666 = 13.87
2x16 / 3.0 = 10.66...
2x16 +3 / 3 = 11.66..
2x16 +7 / 3 = 13
I think you could get 2x8 gb 3000 cl16 then possibily oc it to 3200 at 110ish, not from local though
Shutterbox
3200 / 16 = 200..
2x16 +7 / 3 = 13
But will still need to depend on motherboard qvl for ram right?
Or those r only to show what's tested, doesn't mean others will not work.
thepoorkiddo
Found out that my SSD is broken while assembling new com :p
The com doesn't boot to bios even without the SSD (maybe there's a short circuit somewhere cos it barely boot for 2 seconds before tripping). Might be something else too.
Probably just let it die a naturally cause after 6 years.
Thanks for the very nice offer!
Appreciate it!
SkyShroud
u can always check the review for users using whatever mb
this is the internet you know
Appreciate it!
tripping? no power after turning on? like the cpu/fan turn on for a few seconds then turn off?
most sensible thing to check is ur power cable and psu
ssd/hdd not something easy to spoil, unless is old like 10+ years or heavy users..
