Need help on building a new PC
foxyfox33
Hi guys I am a gamer and a 3D Artist, I wanna build a new PC but I am clueless when it come to which PC parts to get, so I will need you guys to help come up with a build, as for graphic crad I want a RTX 4090 and for the rest of the parts I hope you guys could give me some idea and also my budget is 6k. The software that I use for modelling/rending are Maya, 3ds max, zbrush and other software. Appreciated.
NightRaven49
u might want to consider professional cards like quadro for ur 3d art workloads, these are the cards that have been validated to work stably. consumer grade cards are generally not officially supported.
foxyfox33
COOLER - Corsair H150 RGB 360MM
CPU - Intel i9 13900 KF
MB - Asus ROG Strix Z690-A Gaming Wifi
RAM - G.Skill Trident Z Neo 3600Mhz 32Gb Kit (2x16Gb)
SSD - Lexar NM760 1TB NVME M.2 PCIe4
HDD - Toshiba P300 2TB 7200RPM
GPU - Zotac RTX4090 24Gb Trinity OC
PSU - Corsair HX 1200 80+ Platinum w/ PCIe5 Cable
CASE - Lian Li Lancool 216 RGB TG
Or
cpu intel i7 13700kf
mobo z790 tomahawk wifi ddr5
ram 2 x 16gb adata lancer rgb ram 6000mhz cl 40
gpu rtx 4090 zotac amp extreme airo
ssd 2tb lexar nm620 nvme ssd
hdd nil
psu corsair rm1000x gold rated psu + 12 hvpwr cable
case lian li lancool 2 mesh black type c rgb (comes w 3 argb fans)
COOLER id cooling zoomflow 360xt argb air tower cooler (comes w 3 argb fans)
ADDITIONAL free delivery
wifi comes with wifi + bt
etc. nil
windows windows 11 pro activated
foxyfox33
Ah I see but I also play games sometime.
Phen8210
@foxyfox33
4090 is an excellent choice for 3D workflows, no need to worry about it.
For the rig consider something like
CPU: Intel I9 13900KF
AIO: Arctic Liquid Freezer II 420
MB: ?
GPU: RTX 4090
Cable: 12VHPWR CABLE
RAM: DDR5 6000 (32*2) 64GB Ram
SSD: ?
PSU: Corsair HX1200
CASE: Lian Li Lancool 3
foxyfox33
@foxyfox33
MB: ?
GPU: RTX 4090
SSD: ?
PSU: Corsair HX1200
As for motherboard: z790 tomahawk wifi, Asus ROG Strix Z690-A Gaming Wifi or MSI z690 A pro wifi lga. Which one should i get?
SSD: 2 x 1 tb SSD
Daruul
are u referring to the ddr4 rog z690a? if so i would go w the tomahawk inst since it supports ddr5
