Need help on CPU Casing selection
manisherx
Hello need a mid tower case ATX
budget around 150 - 180 depending
Also a 27" monitor, doesnt have to be 4k. 1080 will do budget 300 is curve monitor any good?
No SLI hopefully there's a fan hub along with the case thanks!
lifeishard
Nzxt 440 lor, got fan hub.
Edit: ps your budget maybe cannot. Maybe see lazada+discount can get for $180?
xiaozozo
fan hub get from doraemon, cheap.
Fractal design R5 w/o side window from Lazada. (window costs $20 more if you wish)
1080p monitor, plenty of choices under $300, pick any brand/bezel width/color you like.
I recently did some searching, and share with you my findings:
HP 27es - white bezel pretty monitor $299 (can ask for cash discount at sls)
Samsung F350 - $269 gloss finish
Dell u2515H - $260+ thin dell bezel, standard good stuff
Philips (not a fan, but you can consider, also <$300 range for 27")
manisherx
Dell you mean U2417H? Hmm I'm considering either DELL U2417H or Samsung 27 Curved forget the model but around the same price
xiaozozo
u2515h, the newer model. recent it show had really good price
http://accessories.ap.dell.com/sna/productdetail.aspx?c=sg&l=en&s=dhs&cs=sgdhs1&sku=391-BBZF
curved monitor same as F350, just curved. Well mainly for "immersive" gaming, but if you using it to watch movies with your friend/spouse, its better to get non-curve. The curve version costs additional $50, per their latest promo brochure
http://www.samsung.com/us/computing/monitors/led/samsung-27-curved-led-monitor-ls27d590cs-za/
