Need help on DIY - Clear Acrylic
human1969
Hello,
I want to change one of my 120mm fan mount to a clear window.
Any idea where i can buy a 120x120mm clear acrylic, preferable with the 4 mounting hole pre-drilled?
(or is there any casing that sell this as spare parts)
Worst case i can get a bigger piece and cut down/drill on my own,
but where can i get the clear acrylic ?
Tried Popular, no luck.
Thanks
royfrosty
Hello,
Thanks
You got to find a shop that does acrylic. I forgot the shop name. But its at veerasamy road. The shops does nothing but acrylics. Cut in all sizes and shapes. Price depends on the thickness and size.
You probably do the whole side panel better. After which use a velcro double side to stick it.
human1969
Thanks.
You mean Yeo Soon Hin signcraft ?
(Blk 633, Veerasamy Road/62949771)
Will check it out.
Rgds
royfrosty
1 questions,
Any idea they do drilling and edge polishing ?
Thanks
That i not sure. Cause it depends on the uncle mood. He happy he do for you. He not happy he tell you he very busy. That's a bad attitude he has.
touchme
$5-$10 at art friend dep. on thickness.
No drill or polish, and you still say diy?
