need help on gfx card
deepblue_82
my card is a gt9600 ====>
but it dont have a hdmi port...
is there a socket or plug which i can use so that it can be used on my tv?
gladiusgg
if u using hdmi cable then get hdmi to dvi converter. shops in sls like cybermind got sell. or u can go marketplace search.
Cryogenist
I presumed it has the DVI ports right?
Just get a DVI to HDMI Adapter or DVI to HDMI cable.
But you MAY NOT have audio output via this method.
deepblue_82
my card is using dvi port.. wah may or may not get the audio output.. then how can i get audio?
Cryogenist
As you know DVI is only a video interface, it was not designed to carry audio signals along with video signals.
From what I read on some of the forums, they may be some cases where manufacturers make use of some pins to carry audio signals as well.
So probably, you have to have alternative method to output the sound.
deepblue_82
hmm
OMG.. means.. no luck.. dont think i can get my com and tv to work togather ~
Cryogenist
Can he use the standard 3.5mm audio jack to output the audio provided his TV has audio-in?
Tell us what kind of audio inputs your TV have or rather all inputs, see whether we can find a way for you.
deepblue_82
its a new 60" 3d tv.. i have to go see what kind of connection has..
i only know hdmi for now..
but so means i need 2 connection.. 1 dvi for video.. and the rca for audio... right?
