justanotherguy93
- Feb 18, 2011
Hi,
As title state, I need help installing my cooler master 212x evo. I tried unscrewing the original cooler out but I'm only successful at that but failed to unscrew the bracket attached to the motherboard. So the cooler master is just sitting in the box collecting dust now.
I've looked through several youtube videos on the installing/uninstalling of that cooler but I can't even remove my old bracket. The problem I'm facing is the original bracket now is quite tight to my motherboard and one of the screw in particular seems to be having a loose thread so I can't unscrew it.
If i use my more force on it. I'm worried it will break.
Fortran built my rig for me and I contacted him to come over to get it done for me but he's currently not available due to personal reasons. Can any bros out there solve this problem I'm facing? It would be ideal if you can come over and fix it...
Thanks community.
Thanks community.
