Need help on my dad iphone 5.
papergoat
The iPhone is from Starhub shop,
1st few months with iOS 6, often reboot.
after iOS 7 update, reboot stop. but when i call him, my side will show engage and his side will show miss call. i got to call again then work.
left 3 months before warranty end. got to solve this ASAP.
PetPet
Moderator
Moderator
Have you tried restoring the iPhone to a clean state?
papergoat
ok, so i got to back up his phone, restore to clean state, then restore back old data?
PetPet
Moderator
Moderator
Hmm you can try that.
After which
Settings > General > Reset > Reset All Settings.
Take note, it's "Reset All Settings"
This would remove
Alarms
Selected Keyboards
Selected Ringtones
iMessage Setting (Send as SMS)
kerrying
Hmmm.. Give reset all settings a try. If it doesn't help, try reset all contents and settings - but this will wipe out every bit of your user data, beware.
It is likely you already have been and used to using iTunes, and updated to iOS7 this way (instead of with OTA, which actually can be pretty flaky and risky sometimes). If it still doesn't help, I will recommend you go the extra long route of using iTunes on Win/Mac, download the entire latest iOS7.x firmware, restore and then set up as NEW, not restore old backup. Assuming you can do without your current user data.
