Need help on new rig
JustAnotherTroll
When did you build your first and what did you got back then?? :s31:
2011.
bought my parts separately then.
bought a 20" monitor 1600x900 first.
bought a palit 460.
then buy the rest.
i5-2400 / asus p8p67 / cm elite 310 / seasonic 620w / 2x2gb corsair xms
in a span of less than 2 years, have changed: msi 570 tf3 -> thermaltake chaser -> 2x4gb gskill -> crucial m4 64gb -> dell 2312hm -> asus 670 dcu2 -> samsung 830 256gb
jin chor~ :o
User-name
Can i buy rig first without SSD then wait for my SSD to arrive then i add in and btw it is easy to shift boot up files in?
royfrosty
You can do so by cloning it. But what i think you should do is just grab the SSD now. As it is already at its lowest. Go ahead and purchase it. Wait for SSD to arrive and get your rig.
gaoxing84
Buy ssd then buy rig. Or buy everything first then when arrive then build.
Cloning I feel isn't that good. Best is clean install
GeForce
say you want re-use ur 'old' SSD.. since you already bought many components they should install for you.. It's easy to do so by yourself anyway :s13:
gaoxing84
but buy liao rest buy from pc themes ssd ownself buy they still assembles?
yes, and if they do charge you assembly fee, they will have to do that since you're paying.
but you can always ask to waive.
PCthemes prices are abit on the high side though. haha
ykgoh
Jialat liao lah. Seems to me that if anything is not as cheap as TradePac, it is considered high.
shadow84
Cannot say pct prices r high wen they jus following rrp. Is tp undercutting all the shops to get volume.
