Need help on passing ippt 2.4km run
veltix
Hi ppl, I need a help on passing 2.4km run. Is there any tips and tricks on how to pass? I forgot the test, what is the required amt time to pass or how many laps?
reddevil0728
See below. Tips to pass is to train. No one hit wonder one.
http://www.channelnewsasia.com/blob/1683732/1425011377000/ippt-updated-standards-data.png
http://www.mindef.gov.sg/imindef/press_room/official_releases/nr/2014/jul/24jul14_nr/24jul14_table.html
http://www.mindef.gov.sg/imindef/press_room/official_releases/nr/2014/jul/24jul14_nr/24jul14_table1.html
http://www.mindef.gov.sg/imindef/press_room/official_releases/nr/2014/jul/24jul14_nr/24jul14_table2.html
spiritGate
depend on your age and ur strength in other station. If you can easily hit full points for situp and push up, ur running can be a long as 15 to 16 mins if i rmb correctly.
tellim
usually fitness come as an overall package.
its not possible u can max ur push up and sit up and yet cant pass 2.4km. :s13:
if u can excel in push up, it means u have train ur body in other aspect as well including weight maintenance and stamina which require some form of cardio.
MudkipFan
mind over body, you must push yourself to run :)
if your stamina is weak, do engage in some endurance running too. for me i run 5km like 2-3 times a week to build up my endurance. you will find that after endurance training, 2.4 should be no kick.
After you got the endurance, do some speed training, such as interval running. This will help you improve your overall timing for 2.4.
j_t_fusion
it is possible.
push up is about upper body strength.
sit up is about core muscles.
2.4km is about leg strength and stamina.
each one test a different aspect of the body so it is possible that you max push up and sit up and fail 2.4km.
match89
I did my 2,4 running 1.5laps and walking 0.5laps. Repeat 3 times. Managed to pass with incentive.
