Need help on prebuild pc
frostbullet
Am looking at this rig from invader.
Is it worth going for 5080 or 5070ti?
AMD RYZEN 7 9800X3D 4.7GHz 8CORE/16THREAD
MSI B850M GAMING PLUS WIFI
COOLER MASTER MASTERLIQUID CORE NEX 360 ARGB
CRUCIAL PRO DDR5 BLACK 6000MT/s 32GB(16GBx2) CL36
MSI GEFORCE RTX5080 16GB GAMING TRIO OC TRIPLE FAN GDDR7
ADATA LEGEND 900 PRO 2TB 7400MB/s GEN4 NVMe
MSI A850GL-850W ATX3.0 PCIe5.0 80+ GOLD
COOLER MASTER ELITE 502 ARGB BLACK TG
https://www.invaderpc.com/product/specs23/
Should i upgrade psu to 1000w if next time just wanna upgrade gpu?
Might also ask them change cooling from aio to fan cooling instead.
jinsatkilife
What games do u wanna play?
What monitor are u using?
5070ti for value
5080 not worth it imo
Animagamer
5070ti. If willing to spend 20% for 10 % gain then 5080
Change the ram to have cl30 , if budget allow and if there is no option to select you can ask them
For the PSU upgrade I am not sure. For me I got 1000 w lian LI for my 5070ti
86technie
Take note in current situation RAM prices are very high.
Distro have stop brining in certain RAM due to high price.
If you ask for CL30 you may be ask to pay $400+ for 32GB or more.
Only options I saw a week ago when I was at SLS.
Was either T-force or ADATA with CL30 timming but the price are very high.
RAM is that expensive unlike few months ago.
For the case just take note there's no exhaust fan ask them for a Cooler Master CF120 ARGB fan
for rear. This ARGB fan is very cheap about $10+ compare with others maybe more expensive.
frostbullet
5070ti for value
I currently looking to play BF 6 then, i still have some backlog games like Expedition 33 cause still have remaining Gamepass membership. Currently pc facing some stuttering issues. 1440p i think good enough for me, no 4k monitor yet.
Yeahhh i was thinking of waiting for the Super series but computer feels like gonna give up in a couple of months time. CL30 vs CL36 any significant difference?
86technie
Lower is better I usually use ADATA Lancer Blade DDR4-6000 CL30.
Price wise you have to check currently is $400+ past few months was about $150.
BF6 and Expedition 33 are demanding game if stuttering issue recommend is
do a clean install of Windows than try again. (Not reset)
Your old one is Intel or AMD? If AMD Ryzen after do a clean install,
do install AMD chipset driver this will fix micro shuttering issue.
frostbullet
I got quoted via Whatsapp this build
ASUS TUF GAMING B850-E WIFI
THERMALRIGHT PEERLESS ASSASSIN 120 SE BLACK
TEAM T-FORCE DELTA RGB DDR5 6000MHz 32GB(16GBx2) CL30
MSI GeForce RTX™ 5070Ti 16GB SHADOW 3X OC
WD BLACK SN850X 4TB GEN4 7300MB/s NVMe M.2
SEASONIC FOCUS GX-1000W V4 ATX3.1 PCIe 5.1 80+ GOLD (Need to check the stock availability)
CORSAIR FRAME 4000D RS ARGB BLACK TYPE-C
3 X 120MM ARGB FANS
HIGH-SPEED AX WIRELESS AND BT | WIFI 7* + BT 5.4*
WINDOWS 11 HOME UN-ACTIVATED
Total: $2979/-
Will add on additional fans, dont think will up by much with the additional fans.
86technie
ASUS TUF GAMING B850-E WIFI *Change to MSI MAG B850M MORTAR WIFI
THERMALRIGHT PEERLESS ASSASSIN 120 SE BLACK *Change to CORSAIR NAUTILUS 360 RS Liquid CPU
X3D chips do run very hot so best to use a AIO
TEAM T-FORCE DELTA RGB DDR5 6000MHz 32GB(16GBx2) CL30 Or Adata Lancer Blade DDR4-6000 CL30
SEASONIC FOCUS GX-1000W V4 ATX3.1 PCIe 5.1 80+ GOLD *Seasonic is pricey change to Corsair RM850E
CORSAIR FRAME 4000D RS ARGB BLACK TYPE-C - Montech X5
3 X 120MM ARGB FANS *Don't need if change case
HIGH-SPEED AX WIRELESS AND BT | WIFI 7* + BT 5.4* Don't need cuz motherboard have WIFI
Total: $2979/-
Usually they will just add generic ARGB fans.
For case alternative will be:
MONTECH X5 - $70
Above are some highlighted.
You can check with them especially the case.
ragnarok95
Senior Moderator
Senior Moderator
No fear mongering please. AMD will continue to provide updates for 9000 gpus.
-Synchronicity-
Just go Nvidia never got wrong
What? Do u know how many problems popped up during the launch of 50 series? Driver issues, missing rops, the still possible melting cables on 5080 and above?
Both companies have their own issues. You gotta pick your poison because it's a damn duopoly. Intel is basically irrelevant for high end gaming.
Never go wrong huh.
abstrax
3 X 120MM ARGB FANS
Total: $2979/-
Both price oso 2.9k. I rather go for 5080 for better performance. 4TB of nvme ssd dun help to improve performace. If u nid high storage, go for sata HDD or NAS.
-Synchronicity-
Honestly if purely gaming only, 5070 ti is sufficient. 5080 isn't worth the extra money.
Basically pick between 9070 xt or 5070 ti depending on what u want.
If u want to go higher, then 5090. 5080 generally isn't worth it unless you're also using it for AI for example.
