Need Help on solving issues regarding some graphical issues in PC
SlacKKing
Im having issues where the pc crashes the games i play
I think its the graphical issue as i run the games such as bf4, tera, borderlands 2 at auto detect best quality to preformance.
as im using the 144hz monitor, i would set the games to at least 144hz.
Bf4: setting to performance and almost all setting to low except for mesh. yet it still crashes and the error msg is "DirectX function GetDeviceRemovedReason failed with dxgi_error_device_hung ("The devide is hung which is typically caused by issues in the graphics driver or alternatively the application")"
Borderlands 2: i set the to unlimited fps and it still crashes and best ratio for quality to performance.
Tera: Set to auto detect best ratio which it set the slider to 2nd to the right(so i guess my pc can handle the graphical aspect to the game) and as expected the driver fails and crash the game but i do not signout from the game. All i have to continue playing is by ctrl+alt+delete and back to the game. so i try and error the slider lower 1 slide each time until no more crashes. it was at 2nd last from the left. so the game looks bad.
Any solutions or fixes for this errors?
mib500
looks to me GPU issue... you already try clean install on gpu driver??
this issue can also be caused by a failing psu. the psu could be failing and putting out too much ripple or unstable power causing the gpu to stop working. i see u are using an axe power deluxe psu? doesnt sound like a high reliability power supply... i suggest u check your psu too.
SlacKKing
any suggestions for a good psu? i planning to change the to a smaller build with Air 240D case in mind...
SlacKKing
is there anyway to check for this fault b4 buying a new psu?
mib500
you have spare PSU? if yes then you can try first... if no you can bring down the PSU to shop to test for you... so from there you can decide to buy new or not...
SlacKKing
no spare if have also not enough power to run anything from my rig.
cos my house only got 2 desktop 1 is a 2009 pre-love compaq desktop used at the living for "dramas" and anime use
while my is strictly for gaming and dramas and anime as well haha..
SlacKKing
hmm only way i can think of is to download occt. run their psu test. see what happen... and then report here. hopefully it dont cause psu to blow up...
i did the test in under the powersupply tab and they give me many screenshots.
so which should i need to post?
dont really need to post the ss. the point of the test to see if the system freezes, hangs, bsod, auto self-reboot or shutdown. this usually indicates psu issue. since that didnt happen not likely psu.
if its artifacts or graphical glitches, it could be gpu issue. btw whats the temps of the gpu during gaming? could be dried up thermal paste or poor contact with the heatsink so the gpu overheats and shuts down to protect itself thus the gpu disappears from the system or looks like its hung.
SlacKKing
okay understood now so i just let it run as long as possible until i see and problem.?
when the testing i received this error " Core #3 over maximum value! Value reached :93, Max Value : 85"
So how to solve this?
SlacKKing
my only guess is the cpu overheat?
since its talking about the core..so i will need to get a new cooler?
any recommendations?
Koenig168
You can try re-seating your CPU cooler and applying a fresh layer of thermal paste.
SlacKKing
eh i changed with H100i still give same error but now the value is 87 when max is 85 for core 3
