Need help on this pc specs
psikyo
Hi everyone. Recently, i'm looking for a new gaming pc. And i was given this specs from a pc builder,so helping to get some second opinion on this before making a major decision.
Processor: Ryzen 5 1600
MB: Gigabyte h270 gaming 3
Ram: Gskill tridentz rgb 3000mhz 16gb
SSD: 120GB (builder didn't state the brand)
HDD: 1TB (builder didn't state the brand)
GPU: Asus strix gtx1060 6gb rgb
Power supply: Thermaltake 650w rgb psu
Casing: Thermaltake view 31 rgb
Others: Thermaltake riser cable
Cooling fan: Thermaltake riing plus 3 in 1 pack
OS: win 10 64 bit
Thanks for your input.
ethan89
Kinda hard to comment coz we aren't sure what's your budget and your requirements.
How much is the seller charging you for this specs btw?
Would strongly suggest that you make the purchase and building it by yourself. U will be able to gain plenty of knowledge as well as better cost savings.
Koenig168
Hmmm .... I didn't know you can fit a Ryzen CPU onto a Kaby Lake MB. :s13:
kamipify
Piece of advise , dun buy from that shop
Their pairing of CPU and motherboard imba
RyanRabu
Haha 10/10 ryzen mobo, the gpu will cost more for aesthetics if you're into that, same for case and fans. Can easily upgrade to a 1070 maybe even 1080 from some cost savings from OS and that very compatible mobo if gaming performance is something you're aiming for
leoleong
OS: win 10 64 bit
I think he quote you the wrong motherboard. AMD Ryzen is using AB350 or x370 board, that board in your post is an Intel board.
psikyo
My budget is 2.2k. For gaming specs
psikyo
Does that guy know what he's doing? Intel mobo ryzen cpu big no no....
I needa defend this. The specs that i listed was from other forum. The guys over there suggested ryzen 5. They said that ryzen 5 works better with the stated above ram. The original cpu was intel 5 7500. Sorry i didnt stated on my original post. Apology.
psikyo
So any suggestion if i were to use ryzen 5 with the rest of the spec? As per just now said, ryzen was suggested from another forum. Originally it was intel 5 7500. Budget 2.2,for gaming. Apology for didn't mentioned earlier.
psikyo
Yes, I'm into gaming. But i really love the aesthetic. It was what i requested from the builder. Understand from your point of view.
ragnarok95
Senior Moderator
Senior Moderator
2.2K. Wait for people here to SIC you the build.
That setup you show here is a rip off, with a 120GB SSD.
psikyo
Sorry that i didn't stated the original specs. The above specs was suggested from another forum. Originally, cpu is a intel 5 7500 with the motherboard. Apology
singupingu
Is aesthetic really that important? You look at my rig spec, I can tell you with the right discount, it's 2.4k only or even lesser. And yours is 2.2k?!
Plus that builder even match Intel motherboard to a Ryzen CPU wtf?! Lmao
CASE: Corsair Crystal 460X RGB ($249)
MOBO+CPU: Gigabyte AB350 Gaming 3 + AMD Ryzen 5 1600 ($503)
RAM: G.Skill Trident Z RGB 3000MHz 16GB (2x8GB) ($249)
PSU: EVGA GD 650W ($129)
SSD: OCZ TR150 480GB ($209)
HDD: WD Blue 1TB ($72)
GPU: MSI Gaming GTX 1070 ($645 after applying $100 coupon from Qoo10)
OS: Windows 10 Home ($11 via carousell)
Addon: Corsair SP120 RGB 3 pcs without controller ($84 from t258jgn carousell page)
TOTAL: $2151
Prices quoted from PC theme or otherwise stated.
Sent from PM me if you wanna build a DIY PC or wanna learn how to make one yourself :D using GAGT
