Need help on what to upgrade
Spladox
Hi! My current rig is listed below
Casing: Eclipse P400
Mainboard: asus b85m-g
CPU: Intel i5-4570
PSU: Seasonix 650 X gold
Ram: Corsair Vengence 2x4GB ddr3
Graphic: Gigabyte R9 280x
SSD: Intel 128Gb ssd
Cooling : cooler master poseidon 120m
Currently playing FFXIV on standard settings and i get very frequent fps drop into the 40s. Should i be looking to upgrade the gfx or the cpu? my budget is around 1.5k or so for an upgrade together with a new monitor if possible.
Audiology93
CPU: Intel i5-4570
GPU 1st. Can consider getting the i5 8400 if really wanna upgrade CPU. GPU wise, go for 1070.
Sent from Xiaomi REDMI NOTE 2 using GAGT
pinkahlao
Just check the power requirements for the GPU. Your seasonic 650W should be able to handle up to 6GB.
thank you! So another question i have is that my current cpu will have no problems running 1060/1070?
Spladox
Thank you. Just got a 1070ti and 500gb ssd. the 1070ti got 8gb vram will my psu be able to support it?
it_geek
use an online psu calculator - take that number and times 120% - and take the closest highest value.
kamipify
GPU than RAM
if wan change cpu than change the whole thing sua
650w can de no problem
Spladox
noidea
TS ... like you, im using the same chip set and psu.
I think you're well off with new GFX card like 1070 Ti ( which you already had )
and add another 8GB to your ram
I still feel that our system can go for another year or two.
