JingKang95
- Jul 19, 2013
Planned build:
G.Skill Ripjaws-X 2133 mHz 8gb (2x4) RAM~120
Asrock Extreme 4 + i7 4790k ~650
Windows 8 Home Prem ~140
MSI GTX 970 Twin Frozr ~575
Toshiba 7200 rpm 2TB HDD ~94
Samsung Evo 250 SSD ~175
Superflower Leadex 650w ~150
Corsair Spec 03 ~90
Samsung DVD RW ~20
Armegeddon Ak700 keyboard ~20
LG 22M45D 22 inch 1920x1080p Monitor ~150
How do I pick a case that can fit all of these components? Recommendations, anyone? Preferably with space for future upgrade to dual SLI gpu.
I'm planning to also do a bit of OC, so if anyone would recommend a cooling system which is compatible with the case I'd ve really grateful.
Budget is $200.
Corsair Spec 03 ~90
Samsung DVD RW ~20
Budget is $200.
