NEED HELP REGARDING UPGRADES OF PC !
Kyralenchelo
Hi all , need advice on which parts to upgrade so i can play higher end games such as bf1 , crysys , battleground , gta 5 and such
my current builds are :
Motherboard : MS-7826 (Kaili)
Processor : Intel Core i7 4790 CPU @3.6GHZ/3.6GH
Memory RAM : 8GB (DDR3)
Graphic Card :NVIDIA GeForce GTX 745
Hard Drive : 1TB
Power Supply : Internal 300W (100V-240V)
OS : Windows 10 home 64Bit
Able to play at 60fps 1080p
BUDGET : $350
dgenex
30/60 fps counted as can play? What graphic settings and 1080p/1440p?
I would upgrade GPU and PSU.
To play those games for ur budget should get a GTX1060 and a reputable >=450W PSU. Should be able to get around 60 frames
I think will exceed budget but im not an expert on this though better ask the other bros here for advice :)
Kyralenchelo
Thanks for the advice bro . Will update my question
ZrE0_Cha0s
btw is this a pre build pc??? mayb u can tell us which casing u using??? but from what i think u can just grab a GTX 1050ti and that's it, tone down the graphic settings to make it playable.
ragnarok95
Senior Moderator
Senior Moderator
It's a HP desktop. Slimline series or Phoenix series or Envy series?
Rashkae
Best to upgrade your keyboard first. Your caps lock was stuck.
Kyralenchelo
Yes this is a pre build pc . I have a 700-392d hp envy case
