Need help selecting monitor
Exclusive10
My Dell E1909W has serve me a good 8 years and is time to retire. It is starting to show white lines across the screen, and tend to flicker. Some ill days, the screen even gradually become blurrish and i need to on/off my monitor to get it back working.
Am not a tech savvy person, so here i am coming in to seek expert advice on the next monitor to adopt.
My requirements:
1) Basic usage - no an avid gamer, mostly watching videos & tv shows
2) On for quite long - Can up to 10 hours a day
3) Prefer something that is good for the eye (some blue light protection etc?)
4) Am running on an old pc, not sure if the the graphic is too old for a too good monitor? - intel(r) uhd graphics 630
Also would like to ask if u know of any upcoming sales as well ?
I did abit of researched and understand that prism monitor which has been a hyped is not exactly a good purchase? I got a Prism TV and it was kind of good but when i try to search for their monitor, it wasnt as good as their tv. seems like Dell is the upcoming monitor brand to get?
Rashkae
There was IT Show just ended this weekend. Dell direct online is the best place to get.
The main difference is if you need height adjustable stand or not
Exclusive10
very need. am not laying on a flat table top. my table has a 8cm sink into to put monitor de.
Exclusive10
Hmm... i tried to compare a couple of monitors from dell direct and online platform, it seems online platform has better price.
Dell UltraSharp 24 Monitor: U2419H
Dell UltraSharp USB-C Hub Monitor - U2421E
The above 2 model worth a 150 diff ?
2421 has WUXGA while 2419 is 1080P . WUXGA really that good ?
nod32fan
I have the u2421e. I would say the extra 150 is worth it if you absolutely need the type C connection and the Ethernet.
The wuxga resolution is great to scroll less. But that's just for my use case.
Rashkae
Depends on your use case and if you need full HD or higher resolution
aCidz
If you don't have any specific requests, a 24" Dell S series for $160 is sufficient.
neobear224
I'm currently using the Acer Predator XB271HU 1440p 144hz monitor from 2016. Has served me well for close to 5 years now.
Exclusive10
that's quite a solid one. but for me , getting a new monitor cant possibly be getting a sturdy old model tt can last for 5 yrs mah. gotta get as of now, the latest technology de. mine last for good 8 years, abit cant bare to discard.
thanks for the reviews and advices.
Am now aiming for Dell U2419H
pls feel free to share if anyone come across a good price for this. else i am trying to wait till lazada sales to see if there's any promo.
DarthGW
how does dell segregate their monitor under the U/P/S series? which one is the entry or pro levels?
tsteo77
What are the key things to consider other than the size of the screen? Looking to buy 1 as well.
1) IPS or TN panel.
2) quick response time .
3) refresh rate.
4) blue light filter.
5) hdmi and display port.
Goodshot
I think U series are overrated for nowadays. Because LG using same panel / qty of ips with half the price .
So basically ur only paying for the premium return service for the extra few hundred dollars
Steyr69
All the sellers had coincidentally increase price for monitor. The Dell S cost $30 more.
Knife really sharp taking advantage of WFH.
jtjt00
Dell UltraSharp USB-C Hub U2421HE has built charger able to charge laptop connected via USB-C cable.
It is a single cable for monitor to charge laptop and video signal from laptop to monitor.
You don't need even the laptop charger.
