Need Help !!!!!!!!!SSD FULL
ragudevil
hi i have installed a 60GB ssd in my computer as a boot drive. but the problem is that many essential programs and files are getting installed in it makeing the ssd full. Now when every i try to open pictures or download small files from the internet is states insufficient memory. Is there a way to use the ssd as just for OS and my 2TB HDD for all the programs and files. because at time the programs installs it in the ssd there is no option to change the drive.
Thank you
yusoffb01
next time choose advanced settings not express setup. also in ur browser settings change download location
watzup_ken
Thank you
To be honest, 60GB is best used as a cache using Intel's SRT. This way, you get a snappy desktop, and still plenty of space to go around on your mechanical drive. But at least make sure your mechanical drive is not a slower 5400rpm drive.
For your current cause, there should always be an option to install your program files on another drive. I've been doing that for a long time since SSD storage sizes is quite limited. ;)
twist_shout
Sorry to OT abit. so lets say i have a 256GB SSD installed windows.
can i installed my Games on the secondary drive (HDD) to play? or i mus installed it on the drive that has the OS?
jtjt00
Installation of applications/games should be on SSD drive, else the mechanical HDD will slow down the load time of your applications/games and hence defeat the purpose of fast load time of SSD.
Get a bigger SSD and periodically un-install unwanted/unused stuffs.
ctingyee
You may install the program/games in your secondary drive (HDD).
My case is I install Windows 7 and any online-multiplayer games (such as CoD Black Ops 2, Battlefield 3) in my 512GB SSD, any games (for example, Deus Ex: Human Revolution)/ software which does not require online are installed in my 1TB HDD.
Use ccleaner to clear the cache or temporary file to clear out some space, those files are probably left over after they were used to install software in your temporary folders.
