Need help! Suspected mobo failure
Ap3s
I was trying to troubleshoot my PC which cannot boot up.
First casualty is the PSU. PSU cannot be powered up. Tried the paper clip test and it's still not running.
Hence, I tried to test the remaining parts using my bro's computer.
1) Connected my PC to his PSU. Was able to power up my PC but no display and beep sound.
2) Remove all parts (GPU, RAM, HDD) from mobo and power up. No beep sound but mobo lights are on.
Tested my GPU on his computer - Working fine
Tested my RAM on his computer - shows overclocking failure (I'm not sure why but probably due to freq issue with his mobo)
I highly suspect that my mobo is a goner. Any other test to confirm that?
If mobo is really spoilt, how do i check if CPU is ok?
I would like to reuse as any working parts as possible so i guess i would only need to replace my mobo+CPU and PSU. Any recommendations?
Intel Core i5 (750) 2.66GHz + MSI P55-CD53
Team Elite DDR3 4GB Kit (2x2GB)
WD Blue 500GB
Palit 512MB 250 GTS
Andyson 550W PSU
Coolermaster 310 ATX
hj_dragon
Have you tested your psu in your brother pc? Is it able to boot. Have you used your brother ram on your pc? Mostly can be either psu + ram or psu+mb+ram or just the ram.
Ap3s
thanks all! resetting BIOS does the trick. so much hard work to troubleshoot
I would only need to replace the PSU. Any recommendations?
Based on the specs below, any recommendations if i were to do a minor upgrade? SSD? can i get more RAM to use with my existing setup?
WD Blue 500GB
Palit 512MB 250 GTS
Andyson 550W PSU
sglords
I think can overhaul when new processors come out
If not using it for gaming and jus basic usage then do minor upgrade by add on min 120gb ssd as boot drive and run application.
yusoffb01
WD Blue 500GB
Palit 512MB 250 GTS
Andyson 550W PSU
Like that 350w enough
