Need help to build a low power rig
sellun
Hello all, I'm new to building computer and would like to try building/learning one since i'll be free for 2 months. I've read guides about building a rig but i still need recommendation on what parts should i get..
I'll be trying to build a cheap, low powered home theatre rig.
have to be low powered as I will be leaving it on most of the time. Other than videos, most likely will be used for basic web surfing and torrent-ing..
Have to have dual screen as i have 2 monitors.
budget wise.... as cheap as possible!
Any bros can help out? :o
sellun
oh just need the cpu and no other accessories. Prefer to have a small and nice casing
haylui
maybe you can state your budget for others to recommend you the components...
sellun
okay! :) hmmm, anything from $300 - $400+ i guess. budget is really not my top concern tho.
HDD just 500gb will do, preferably have USB 3.0, with at least 1 hdmi and 1 vga output and I want to include OS as well..
royfrosty
Asrock B75M DGS + G1610 ~ $117
ADATA 4gb 1600mhz ~ $45
Toshiba 500gb ~ $60
HEC True Power 300w ~ $35
Silverstone SG05 ~ $88
Windows 7 Home Premium 64bit OEM ~ $115
Total ~ $460. Buy at tradepac. DIY
Shutterbox
Anandtech site say haswell gives truer 24fps when viewing movies leh
