Hi bro, does the below means my HDD is going to up lorry anytime?
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (40020) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 3
3 Spin_Up_Time 0x0027 197 178 021 Pre-fail Always - 5150
4 Start_Stop_Count 0x0032 098 098 000 Old_age Always - 2766
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 069 069 000 Old_age Always - 22772
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 37
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 23
193 Load_Cycle_Count 0x0032 049 049 000 Old_age Always - 453122
194 Temperature_Celsius 0x0022 092 085 000 Old_age Always - 58
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 1
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
SMART Error Log Version: 1
ATA Error Count: 2
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 2 occurred at disk power-on lifetime: 22536 hours (939 days + 0 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 80 c8 a4 3a ee Error: UNC 128 sectors at LBA = 0x0e3aa4c8 = 238724296
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
c8 00 80 80 a4 3a ee 08 13d+15:06:24.588 READ DMA
c8 00 80 80 79 3f ee 08 13d+15:06:24.534 READ DMA
c8 00 80 00 79 3f ee 08 13d+15:06:24.534 READ DMA
c8 00 80 00 a3 3a ee 08 13d+15:06:24.514 READ DMA
c8 00 80 80 a3 3a ee 08 13d+15:06:24.514 READ DMA
Error 1 occurred at disk power-on lifetime: 22536 hours (939 days + 0 hours)
c8 00 80 80 a4 3a ee 08 13d+15:04:27.851 READ DMA
c8 00 80 00 a4 3a ee 08 13d+15:04:27.851 READ DMA
c8 00 80 00 ce 35 ee 08 13d+15:04:27.793 READ DMA
c8 00 80 80 ce 35 ee 08 13d+15:04:27.793 READ DMA
c8 00 80 80 a3 3a ee 08 13d+15:04:27.785 READ DMA
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 22393 -
# 2 Extended offline Completed: read failure 10% 11831 281039120
# 3 Short offline Completed without error 00% 11616 -
# 4 Short offline Completed without error 00% 8133 -
# 5 Short offline Completed without error 00% 2225 -
# 6 Short offline Completed without error 00% 438 -
# 7 Short offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
was never started.
been run.
command.
power-saving mode.
ATA Error Count: 2
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
