Is your model A780L3G ? If yes, the back panel should be like this.
You never indicate whether you use a graphic card. If you do, try using either the blue or white socket (at the back panel) that your monitor can support. See if you get any image on your monitor.
If you don't use any video card, try reseating your RAM modules.
