Need Help to solve my Seagate HDD Problem
iris.shop.99
Hi All,
My Seagate 500GB HDD sometimes cannot be detected. Even if it can be detected, I cannot read the data in the harddisk.
I have a lot of photographs and document files in this drive.
Please advise any shop or company can help to retrieve my data and the price for it. Or is there anyway to retrieve my data. This HDD is not longer under warranty.
Thank you.
datarecovery
You can call Ontrack Data Recovery direct for assistance.
Ontrackdatarecovery.com.sg
They have a clean room as part of the data recovery process.
Mclairs83
model of your drive?
7200.11 barracuda? If yes, you might be plague with the BSY bug issue, upgrade your firmware and see whether it helps.
iris.shop.99
Hi Mclairs83,
Yes my drive is Barracuda 7200.11.
P/N: 9BX154-303
Firmware: SD15
Date Code: 09136
Site Code: SUZH8G
How to update firmware?
Mclairs83
Hi Mclairs83,
P/N: 9BX154-303
Firmware: SD15
Date Code: 09136
Site Code: SUZH8G
Good luck. Update fast once your drive is detected. If not, there are high chances of getting it bricked once u power down your PC.
As the top post already mentioned about the firmware. there are instructions on how to do so.
I highly recommend you to backup all your data after flashing the firmware, as updating to SD1A does not solve the issues permanently.
iris.shop.99
Thank you. I will try this during the weekend and report my findings.
Kiwi8
Deluxe Member
Good luck there!
Will be waiting for the results keenly. :o
iris.shop.99
if u still can't get it to work. let me know.
i used to do unbrick HDD for 7200.11 BSY issue. i just need a XP machine to unbrick.
Hi albertlee and Mclairs83,
I used the Firmware update link provided by albertlee, but my model no. is not listed there.
My HDD details are as below:
Serial Number: 6QM05L24
Part Number: 9BX154-303
Model Number: ST3500320AS
Family: BARRACUDA
I tried to search for the latest firmware using the website search feature but when I click on the firmware link, I cannot complete the 30MB firmware download.
What should I do now?
iris.shop.99
Hi All brothers,
I tried to update the firmware but after PC reboot, some message appear and it hangs. Anyone can help me?
Happy New Year to all!.
Regards,
irisshop99
turismo
Hi all, I do affordable data recovery for hard drives and I can try to help do the same for yours. PM me.
